Simple Harmonic Motion of Inverted Simple Pendulum with a Helium Balloon
The discussion centers on analyzing the motion of an inverted simple pendulum consisting of a helium-filled balloon tied to a string. The problem involves demonstrating that the motion is simple harmonic and calculating the period of the oscillation. Key equations include the force acting on the balloon and the formula for the period of a pendulum. A participant initially struggled with the calculations but received guidance on neglecting air resistance and focusing on the balloon's acceleration. Ultimately, they successfully derived the acceleration and period of the motion, concluding their inquiry with assistance from another forum member.
Touchme
A light balloon filled with helium of density 0.175 kg/m3 is tied to a light string of length L = 3.35 m. The string is tied to the ground, forming an "inverted" simple pendulum (Fig. P13.63a). If the balloon is displaced slightly from equilibrium, as in Figure P13.63b, show that the motion is simple harmonic (do this on paper. Your instructor may ask you to turn in this work), and determine the period of the motion. Take the density of air to be 1.29 kg/m3. (Hint: Use an analogy with the simple pendulum discussed in the text, and see Chapter 9.)
Ft = [-(density of air - density of He)Vg)/L]s
T= 2pi*sq.root of L/g
I tried to play around with the formulas, however, I was unsuccessful. I'm not sure if those formulas are relevant to the question. Any suggestion on how to start solving or any hints?
Hint: If the balloon were released, what would its acceleration be? I assume you are supposed to neglect the resistance of the air to the motion of the balloon. You can't have the balloon floating without the air, but you can neglect the resistance effect.
The acceleration would be
a = ((d(air) - d(gas))V - m)g/(m + d(gas)V)
So...
I neglected mass but it says a light balloon...
a = (1.29-0.175)(9.8)V/(0.175V)
a=62.44 m/s
Hmmm... then I use the period formula and...
GOT IT!
thanks OlderDan =D
