Simple integration by parts problem
revolve
<br /> \int \ln(2x+1)dx<br />
u = \ln (2x +1)
du = \frac{2}{2x+1}
dv = dx
v = x<br /> xln(2x+1) - \int \frac {2x}{2x+1}dx <br />I'm not sure how to proceed. Do I separate the fraction in the integrand or do long division?
I think I separate the fraction but I don't remember how. So I guess the question is how do I separate the fraction in the integrand?
You can rewrite the numerator as 2x+1-1, then separate the fraction into 1-1/(2x+1). A slightly easier way of doing this problem would be to rewrite the original integral as 1/2\int \ln(u)du, with u=2x+1, then integrating ln(u) by parts.
Thank you!
So now I have:
<br /> \int \ln(2x+1)dx = x\ln(2x+1) - \int (1 - \frac{1}{2x+1})dx<br />
I'm stuck on the next step. I think I need to remove the 1 somehow from in front of the fraction.
Continuing where you left off:
=x ln(2x + 1) - x + \int \frac{dx}{2x + 1}
The -x term came from integrating -1 with respect to x. The last integral can be done with a simple substitution, u = 2x + 1, du = 2dx.
Don't forget the constant of integration.
Perfect! Thank you.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
