Clever-Name
- 378
- 1
A particle of mass 'm' slides on a smooth surface, the shape of which is given by y = Ax^{2} where A is a positive constant of suitable dimensions and y is measured along the vertical direction. The particle is moved slightly away from the position of equilibrium and then released. Write down the equation of motion of the particle.
Lagrangian
T = \frac{1}{2}m(\dot{y})^{2}
V = mgy
Using the chain rule for my derivatives and plugging in the functions for the lagrangian I got:
L = \frac{1}{2}m(2Ax\dot{x})^{2} - mgAx^{2}
Applying this to the Euler-Lagrange equations:
\frac{d}{dt}\frac{\partial L}{\partial \dot{x}} = 8mA^{2}x(\dot{x})^{2} + 4mA^2x^{2}\ddot{x}
\frac{\partial L}{\partial x} = -2mgAx
End up with, after some cancelling,:
2A^{2}x^{2}\ddot{x} + 4A^{2}x\dot{x}^{2} + gAx = 0
However the solution I have says the final answer should be:
(1 + 4A^{2}x^{2})\ddot{x} + 4A^{2}x\dot{x}^{2} + 2Agx = 0
I can show more detail in my work if needed, I just didn't want to type it all out.
