Simple Pendulum nonlinear second order differential equation
Stantoine
given: dt=-\frac{1}{2}\sqrt{\frac{l}{g}}\frac{d\theta}{\sqrt{sin^2(\alpha/2)-sin^2(\theta/2)}}
make the change of variables sin(\theta/2)=sin(\alpha/2)sin(\phi)
to show that: dt=-\sqrt{\frac{l}{g}}\frac{d\phi}{\sqrt{1-k^2sin^2(\phi)}}
where k=sin(\alpha/2)
given in (A)
Substituting for θ i have gotten to:
dt=-\frac{1}{2}\sqrt{\frac{l}{g}}\frac{d\theta}{\sqrt{k^2-k^2sin^2(\phi)}}
I'm not sure how to go any farther, or how to substitute for dθ
You have to substitute for ##d\theta## as well.
if ##\sin(\theta/2)=k\sin(\phi)##
then ##\theta=?## and ##d\theta/d\phi=?##
Note: ##\sqrt{k^2-k^2\sin^2(\phi)}=k\cos(\phi)##
Differenting both sides and then doing some algebra gives me
d\theta=\frac{2sin(\alpha/2)cos(\phi)d\phi}{cos(\theta/2)}
Also thank you for pointing out that my denominator can be rewritten as kcos(θ). That seems potentially helpful.
If sin(\theta/2)=ksin(\phi), then \theta=2arcsin(ksin(\phi))=2\phi*arcsin(k)?
That won't help unless you can find ##\cos(\theta/2)## in terms of ##\phi##.
(What did you differentiate both sides with respect to?!
It looks like you differentiated the LHS wrt ##\theta## and the RHS wrt ##\phi## which is a nono.)
Why not start by solving the equation for ##\theta## and then differentiating that?
I did differentiate the LHS wrt θ and the RHS wrt phi. Come to think of it, that doesn't make sense at all!
If I were to solve for \theta, I think I'd get:
then differentiating with respect to phi,
\frac{d\theta}{d\phi}=2\frac{kcos(\phi)}{\sqrt{1-k^2sin(\phi)}}
so I can substitute d\theta=2d\phi*\frac{kcos(\phi)}{\sqrt{1-k^2sin(\phi)}} in?
That's the idea!
Notice how that aready looks a lot like the answer you are looking for?
And you have a ##k\cos(\phi)## in the numerator to cancel out that stuff you already have in the denominator!
Aside:
trig function in LaTeX look better if you put a \ in front of them so ##\arcsin(\phi)## instead of ##arcsin(\phi)## see?
I see the difference! I'm a little new here for thanks for the tip.
I believe I was able to solve the problem with your help. It is very much appreciated! Thanks for the expedient responses and have a nice holiday season.
No worries - not holidays in NZ yet though ;)
