Simple positron diffraction problem
asdf12312
A beam of positrons (positron ≡ antielectron) travels at 0.001% the speed of light and impinges on a slit that is 1 μm wide. Use modern units to find the angle θ between the center line and 3rd minimum of the resulting diffraction pattern. How far away (in cm) would you locate a detector so that the 3rd minimum is spaced 20 cm from the center line?
wavelength = hc/pc where hc=1240nm*ev
and i believe p=mv where mass is same as electron =9.1e-31 and so pc=mc2=0.511e6
there is example in my notes where pc=mv*c=mc2(v/c) was used to find wavelength if v was given in % of c. but this is where I get confused because in the notes 0.1%*c becomes 0.001 somehow (10-2?)
for minima: (n-0.5)*wavelength=d*sin(θ) where asked to find θ, d=1e-6m and n=3 for this problem.
so.. after various incorrect attempts it give me what the answer should be but problem is I don't know how to get it :(
θ = 46.7200 Degrees
Tries 3/3
L= 18.8339 cm
Tries 3/3
I think i should do something like find wavelength using 1240/(0.511e6*0.001) and if I do I get 2.43 nm. but i think I am doing it wrong because I get wrong θ :(
Sure.
100% = 1
10% = .1
1% = .01
and so on.
You used the wrong equation to find the angle. This is a question about diffraction, not interference. Your equation for the minima should be nλ=asinθ, where a is the slit width (in this case a=1e-6 m) and n=3.
Your wavelength equation is correct. Wavelength should equal 242.7 nm.
Use Y=Ltanθ to find L.
20 cm is your vertical displacement from center line.
Likes mfb
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
