Simple variable control question.
  • Thread starter Thread starter metalmagik
    Control Variable
To achieve constant velocity in a friction investigation, using a 60Hz motor to spin a threaded rod with a nut attached to the object is suggested. This setup provides a constant linear velocity through the motor's consistent angular speed. While it does not create constant acceleration, it maintains a constant force that counters the frictional force in the experiment. The method is appreciated for its effectiveness in meeting the experiment's requirements. This approach is timely and helpful for completing the lab assignment.
metalmagik
Hello, I am making a lab investigating friction of an object and I just need a "method" of controlling acceleration in the experiment so the object travels at a constant velocity. This is really the only way I can think of having the experiment work out correctly so I really need help with this. Any help is greatly appreciated, thank you!
How about a 60Hz motor spinning a threaded rod, with the nut attached to your object? The constant angular velocity of the motor will give you a constant linear velocity at the traveling nut. It's not a constant acceleration, but a constant force, which is opposed by a frictional force in your experiment, I would guess...
Thank you, greatly appreciated. This is due tomorrow you just helped me out a great deal. thanks
