MHB Simplifying by combining terms
  • Thread starter Thread starter headbang
    Simplifying Terms
The discussion focuses on simplifying the expression $$\frac{1}{y+1}+\frac{2}{x+2}+\frac{\frac{x+2}{y+1}-2}{x+2}$$ by addressing the third term, which is a compound fraction. Participants clarify that to simplify, one should multiply the numerator and denominator by $(y + 1)$ to eliminate the fraction. The simplification leads to the expression $$\frac{x - 2y}{(x+2)(y + 1)}$$, and further steps involve combining fractions correctly. The conversation highlights the importance of careful manipulation of terms to achieve the final simplified form.
headbang
Ok.. What about this one?
this is where I am at:
\left(\frac{x+2}{y+1}-2\right)
Mathematics news on Phys.org
Let's clear that mess in the 3rd term:
$$\frac{1}{y+1}+\frac{2}{x+2}+\frac{\frac{x+2}{y+1}-2}{x+2} \cdot \frac{(y + 1)}{(y + 1)}$$
$$\frac{1}{y+1}+\frac{2}{x+2}+\frac{(x+2) - 2(y + 1)}{(x+2)(y + 1)}$$
$$\frac{1}{y+1}+\frac{2}{x+2}+\frac{x - 2y}{(x+2)(y + 1)}$$
Now just add the fractions. Give it a try and tell us how it goes from here.
-Dan
Can the ansver be:
$$\frac{2+x}{4y}$$ And i stil don't understand how you solved the messy 3rd term..?
what i did from where you left me..
$$\frac{x+2+2y+2+x-y}{(x+2)(y+1)}$$
$$\frac{4+2x+y}{(8x+2)(y+1)}$$
$$\frac{2*2+x*x+y}{x*y+2y+y+y+2}$$
I moved the posts associated with your new problem into a separate thread. We ask that new questions not be tagged onto an existing thread...this way the original thread does not potentially become convoluted and hard to follow. :D
headbang said:
Can the ansver be:
First things first: The equation above is almost correct. You missed a 2 in the last term in the numerator. It should be
$$\frac{x+2+2y+2+x-2y}{(x+2)(y+1)}$$
Okay, the third term in your problem is what is known as a "compound fraction." Compound fractions have fractions in the numerator, denominator, or both. Let's take this one step by step.
[math]\frac{\frac{x + 2}{y + 1} - 2}{x + 2}[/math]
The goal here is to remove the fraction in the numerator. Clearly if we multiply the numerator by y + 1 the fraction goes away. And what we do to the numerator we need to do to the denominator. So:
[math]\frac{\frac{x + 2}{y + 1} - 2}{x + 2} \cdot \frac{y + 1}{y + 1}[/math]
Now simplify:
[math]\frac{\frac{x + 2}{y + 1} - 2}{x + 2} \cdot \frac{y + 1}{y + 1} = \frac{\left ( \frac{x + 2}{y + 1} \right ) (y + 1) - 2(y + 1)}{(x + 2)(y + 1)}[/math]
[math]\frac{(x + 2) - 2(y +1)} {(x + 2)(y + 1)}[/math]
And now go from there.
-Dan
$$\frac{x+2+2y+2+x-2(y+1)}{(x+2)(y+1)}$$
$$2y+2+x-2=x+2y$$
Ok?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
