Sin^4Ө =3/8-3/8cos(2Ө) Prove the following trigonometric identity
The discussion centers on proving the trigonometric identity sin^4(θ) = 3/8 - 3/8cos(2θ). Participants suggest using power-reducing formulas for sin^2(θ) and cos^2(θ) to manipulate the left side of the equation. Confusion arises when testing specific values, leading to the realization that the identity may be incorrect as it does not hold for θ = π/2. A proposed correction suggests the identity should instead be sin^4(θ) = 3/8 - 1/2cos(2θ) + 1/8cos(4θ). The conversation highlights the importance of careful application of trigonometric identities and formulas.
bubbly616
Prove the following trigonometric identity. The question is sin^4Ө =3/8-3/8cos(2Ө)
I think I'm supposed to use the power reducing formulas for trigonometric identities which are
sin^2(u)= (1- cos(2u))/2
cos^2(u)=(1+cos(2u))/2
*Let u represent any integer/value*
To expand the equation I separated the equation into (1- cos^2Ө)(1- cos^2Ө) = 1- 2cos^2Ө + (cos^2Ө)^2. I reduced it because sin^2Ө = 1 – cos^2Ө and after this I'm confused on what the next steps are.
So, a much better post than the first try. Good !
Your other entry is from the righthand side: what have you got for ##\cos(2\theta)## that might be useful here ?
[edit] ah: your second relevant equation !
So you applied the sin^2(u) to the lefthand side of the equation and got (1/4) * (1 - cos(2u) )^2 right?
Next expand the
(1/4)*(1 - cos(2u) )^2 = (1/4) * ( 1 - 2*cos(2u) - cos(2u)^2 )
next apply the cos^2(u) rule to the last term and see what you get.
Likes bubbly616
As well as the power reducing formulas, you'll want to glance at the double angle formulas.
Likes bubbly616
But now I see a problem coming up:
let ##\theta = \pi/2\ \ ## then ##(sin\theta)^4 = 1\ \ ## and ##\ \ 3/8-3/8\cos(2\theta)=3/4## !?
So no identity at all !
Or did I read the original thingy in the wrong way ?
Likes bubbly616
I believe the identity ought to read ##\sin^4(\theta)=\frac 38-\frac 12\cos(2\theta)+\frac 18\cos(4\theta)##.
Looks like someone turned that ##4\theta## into another ##2\theta##.
Likes bubbly616, Qwertywerty and jedishrfu
Why would u have to be an integer?
