Can Two Points on a PV Curve Represent the Same State in Thermodynamics?
  • Thread starter Thread starter initiator
    Gas Pv=nrt
The discussion explores whether two points on a P-V curve can represent the same thermodynamic state, particularly when a system expands and does work while maintaining constant internal energy. It asserts that free expansion of a gas is inherently irreversible, as equilibrium is never achieved, and reversible expansion requires the external pressure to be slightly less than the internal pressure. Additionally, the relationship between enthalpy and internal energy is examined, highlighting that internal energy changes during a reaction due to the formation and breaking of chemical bonds, even under isothermal conditions. The conclusion emphasizes that internal energy is not solely a function of temperature, which explains why it cannot be assumed to be zero during such processes. Understanding these principles is crucial for accurate thermodynamic analysis.
initiator
suppose an Q amount of heat is given to a system initially at v_1 & p_1 vol and pressure. and the system does a equal amt of work on the surroundings so that delU=0. but in doing this work system has expanded to volume v_2 and has a pressure p_2 due to which it is at a different position on the P-V curve. is it possible that two points on the PV curve represent the same state.
Is free expansion of a gas a reversible process if so how p_ext in this case is always far lower than p_int and the system is never in equilibrium through out the process. how can be then free expansion achieved reversibly. (for the process to be reversible p_ext shuld be infinitesimal greater than p_int isn't it so?)
In case of enthalpy delH=delU + deln_g(RT). this relation is derived assuming that the process is isothermal. and since PV=nRT is used the gas is assumed to be ideal then why in this case is delU is not taken as zero? where n_g is the difference between the no of moles of product formed and the moles on the reactant side.
Of course, for isothermal expansion of an ideal gas, the final state can be the same as the initial state if no expansion has occurred.
Free expansion is always irreversible. For expansion to be reversible, the expansion must be quasi static such that the external pressure is only slightly less than the mean pressure of the gas.
The internal energy of an ideal gas reaction mixture is not a function only of temperature. It changes as a result of making and breaking chemical bonds, so that there are changes in the amounts of the various chemical species that are present. So, when a chemical reaction occurs at constant temperature, ##\Delta U## is not equal to zero.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
