Singularities Complex Analysis
Darth Frodo
Determine the location and type of singularity of f(z) = 1/sin^2(z)
I'm not really sure how to calculate this. At this point, we don't have explicit formulae for the coefficients of a Laurent series so I really don't know what to do. Taylor series?
Any help would be much appreciated. Thanks.
You could just use the definition. A function 1/f(z) has a singularity at z=a if f(a)=0. If (z-a)^n/f(z-a) has a finite limit as z->a then then the singularity is order n. Where does sin^(z)=0 and what power n do you need?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
