Sinusoidal Waves homework help
The discussion revolves around solving a homework problem involving two transverse sinusoidal waves described by specific wave functions. The main task is to determine the maximum transverse position of the medium at given positions and to find the smallest values of x corresponding to antinodes. A participant initially attempted to use derivatives to find maximum values but faced confusion. They later realized that a simpler approach, assuming the cosine component equals one, allowed for straightforward calculations. The conversation emphasizes the importance of understanding wave functions and maximizing them without unnecessary complexity.
PhysLiz
Two transverse sinusoidal waves combining in a medium are described by the wave functions
y1 = 5.00 sin π(x + 0.900t)
y2 = 5.00 sin π(x − 0.900t)
where x, y1, and y2 are in centimeters and t is in seconds. Determine the maximum transverse position of an element of the medium at the following positions.
(a) x = 0.210 cm
(b) x = 0.520 cm
(c) x = 1.30 cm
(d) Find the three smallest values of x corresponding to antinodes. (Enter your answers from smallest to largest.)
Equation of a standing wave: y = 2Asin(kx)cos(wt)
by my calculations,
y1+y2 = 10sin(pi*x)*cos(0.9*pi*t)
and from here I'm a bit confused. I tried deriving (y1+y2) with respect to time, and setting this equal to zero in order to find the corresponding x-values , but I just ended up with 0-values so either I did it incorrectly or that's not the right method. Thank you in advance for any assistance!
You can certainly maximize the function by using derivatives, but you'd have to show your work to let us see where you went wrong. It's probably very useful to sketch sin and cos by hand and recall what angles are extrema and which are zeros. You can go back and verify those using derivatives.
it turned out to be much simpler than I thought. no derivatives involved - just assume the cosine component = 1 and then plug and chug to solve for 10sin(pi*x) values. but thank you!
