icystrike
- 444
- 1
the qns is : sketch the graph of y=3ln(x+2) , showing clearing the asymptote and the x-intercept.
im wondering wat is asymptote and how we find it..
redargon said:An asymptote is a vertical or horizontal line (sometimes oblique, but at your level at the moment, I don't think they will be)drawn through the x or y value where the function goes to positive or negative infinity. To determine them you have to evaluate the function to a limit of infinity or to a value that will cause the limit to be infinity.
so at what value for x would 3ln(x+2) go to +-infinity? What do you know about the limits/boundaries of the ln function?
redargon said:when will ln be infinite? ie. ln(what)= +-infinity?
redargon said:have you got a calculator that can do ln? You'll need something to be able to work out what the points are. Put some values in and ln them and see what happens. Eg. what is ln(1), ln(2), ln(1000), ln(1000000000000), ln(0), ln(-1), ln(-2), ln(-100000). try to get more familar with the ln function. Let me know if you get any interesting answers.
redargon said:so, start picking some values of x and start working out the corresponding y values and plot the graph. So if x cannot be negative then there is a boundary where the function cannot cross at x=0 or for any negative number. This boundary is your asymptote. This obviouslt has to apply to your problem y=3ln(x+2), at x=0 3ln(x+2)=3ln(2) which is a point. but when x=-2 then 3ln(x+2)=3ln(-2+2)=3ln(0)... etc
Ln(1) does exist, it is equal to 0. When does ln(x)=1? any ideas? hint: think about what ln means: ln(x) =loge(x). remember that the log1010=1.
icystrike said:erm it shud be still infinite rite?
redargon said:ln(0) is your asymptote. y=3ln(x+2) therefore when x=-2 y=3ln(0)=infinity. So your asymptote is a vertical line drawn through the x-axis at x=-2.
redargon said:ln(1)=0
ln(0)=infinity
check it on your calculator
\lim_{x \rightarrow 0^+} ln (x ) = -\inftyredargon said:ln(1)=0
ln(0)=infinity
Mark44 said:\lim_{x \rightarrow 0^+} ln (x ) = -\infty
You were off by quite a lot--about as much as it's possible to be off.
Mark44 said:What's with "erm"? You seem to start your posts with this.
"but what can we conclude leis?" - What is leis? I'm sure you're not talking about the flower strands they give visitors to Hawaii.
In your original post you were asked to graph y = 3 ln(x + 2). Part of what you needed to do was find vertical asymptotes. This function is very similar to y = ln x, but it has been translated two units to the left. Any vertical asymptote for y = ln x will also be shifted two units to the left. There are no horizontal asymptotes.
