Slightly Harder Cauchy Integral
  • Thread starter Thread starter knowlewj01
    Cauchy Integral
knowlewj01
Evaluate the integral I_1 = \int_0^{2\pi} \frac{d\theta}{(5-3sin\theta)^2}
I start off by switching the sine term for a complex exponential e^{i\theta}=cos\theta +isin\theta
I will consider only the Imaginary component of the solution.
now make the substitution: z=e^{i\theta}
so we have:
I_1 = Im\left(I_2\right)
I_2 = \int_0^{2\pi} \frac{1}{(5-3z)^2}\frac{dz}{iz}=\frac{1}{i}\int_0^{2\pi}\frac{dz}{z(5-3z)^2}
so we have 2 poles: a simple pole at z=0 and a second order pole at z=5/3
I'm not sure wether i need to include both residues. the question does not indicate the contour to integrate. Should it be a unit circle? I'm not sure why it would be. any ideas?
The original integral is over θ from 0 to 2π. When you change your integration variable to z=exp(iθ), what values can z take?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
