Small Genset Project - Feedback Request
The discussion centers on building a small 3kW genset that is portable and potentially powered by gasoline or diesel. A single-cylinder four-cycle engine is recommended for simplicity and compliance with emission regulations, while a diesel engine would be heavier due to its construction requirements. Suggestions include sourcing engines from motorcycle dismantlers or lawnmower shops, as well as considering the engine's RPM for longevity and efficiency. The importance of matching components and understanding the intended use, such as charging batteries or providing household power, is emphasized. Overall, leveraging existing technology and making informed choices about engine specifications is crucial for the project's success.
ElectricPaint
Hello everyone!
I want to do a small project, and would like your thoughts:
I'm going to build a small genset, with a target power output of 3kW, and "one person carry" possibility.
Using liquid fuel, probably gasoline.
Although if diesel is a possibility, that would be interesting to study.
Any thoughts on what engine can be used?
I thought a small engine, like the ones Honda uses in their small power plants.
Honda's small gensets go up to 2kW, and are still "one person carry".
Ideas on what engine to use for this?
Thank you!
For such a small unit, a single cylinder gasoline engine is probably the simplest.
A two cycle motor would be cheapest, but I think emission rules have curtailed their availability, so a 4 cycle motor will probably be the best bet.
A diesel would be substantially heavier, the 20:1 compression mandates hefty cylinder walls.
If I wanted to build a small, lightweight generator I would use the example of Honda and copy their product. I am humble enough to admit that Honda has invested millions of $ and thousands of engineers over many years to create their product, and that I am only one person with limited experience/education. Why would I sit in a vacuum and ignore all the advances they have achieved?
Of course, there is always room for improvements in efficiency. I suggest you look for ways to improve existing "top of the line" gensets.
Without knowing your constraints (i.e., cost, time, fabrication capabilities), it's hard know exactly what might be helpful. If it was my own project, I'd probably begin by going to a motorcycle dismantler (junk yard) and check the prices of available engines. It won't do any good to have a 3kw generator if you can't afford a big enough engine to spin it.
You should decide what you want to use it for first...what voltage do you want...or are your trying to charge 12 volt batteries, for example?
3kw PORTBLE from miscellaneous components may not be so easy...HONDA has carefully matched components.
1 hp is about 3/4 KW...so you'll need about 4 of those units to generate 3 kw...a four HP engine or a bit larger...I think a typical 22" lawn mower engine is about that size...check to be sure...so you could probably get a used four cycle engine cheap from a lawnmower shop.
And if you are charging 12 volt batteries, maybe a used alternator from an automobile. You should also consiuder the rated engine RPM...if you want longer life, a engine rated at 1800 RPM will likely do better than one run at 3,600 RPM. You'll to generate about 14 volts for actual charge.
If you are trying to generate alternating current, for household, that's 60 hertz in the US and 50 hertz in Europe, so you'll have to control the engine RPM to get the output frequency you want.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
