So you'd use the top loop and the right-hand loop.
  • Thread starter Thread starter Princess19
    Experiment
The discussion revolves around a circuit analysis problem involving the application of Kirchhoff's laws to determine the currents i1, i2, and i3 in a circuit with multiple loops and a junction. Participants are tasked with developing equations based on the circuit diagram provided.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to develop three equations, with some confusion about which equations to use and their correctness. There are attempts to clarify the distinction between junction equations and loop equations, as well as questions about the correct formulation of the third loop equation.
Some participants have provided guidance on the structure of the equations and clarified the types of equations needed. There is ongoing exploration of the correct formulation of the equations, with multiple interpretations being discussed regarding the loop equations and their dependencies.
Participants note that the professor's instructions may have been misunderstood, particularly regarding the number of equations needed and their relationships. There is mention of the complexity of the circuit and the need to choose simpler loops for analysis.
Princess19
http://img251.imageshack.us/img251/3123/photo2152.jpg
i don't know of any..
Ok, so the professor told us to develop three equations, but to only use two of those to try and solve for the currents, i1, i2, i3.
All i know is the currents coming in are equal to the ones coming out.
So, I probably have these wrong, but here are the equations so far.
1) I2 + I3 = I1
2) -I3R3 - V2 - I1R1 + V1 = 0
3) -I3R3 - V2 - I1R1 + V1 = 0
are these wrong? help me get them right, I am so lost.
Hi Princess19! :smile:
(try using the X2 icon just above the Reply box :wink:)
Your 1) and 2) look right :smile:
but you've copied your 3) wrong, it's the same as 2) ! :redface:
btw, I think you've misunderstood your professor …
… this circuit has 2 loops, so you do need 3 equations to solve it: one junction and 2 loop equations
I think your professor meant that there are 3 loop equations (left loop right loop and outer loop), but you only need 2 of them (because they're linearly dependent), plus a junction loop, making 3 …
and he wants you to write all three loop equations, but then use only 2 of them :wink:
oops! would this be equation 3?
i3R3 - i2R2 + V2 = 0
he he! :biggrin:
Yes, that looks good :smile:
now solve!​
(btw, you still haven't given the third loop equation. :wink:)
is the first equation a loop equation?
i have no idea about the third loop equation. can you give me some sort of hint to get started on?
The first equation is a junction equation (i'm not sure that's the official name, but it's what I call it :wink:).
The 3rd loop equation is for the outside loop, ie the one with V1 R1 and R2.
would equation 3 be i3R3 - i2R2 + V2 = 0 or -i3R3 - i2R2 + V2 = 0
okay, how about this for the outer loop
V1 - I2R2 - I1R1 = 0
(just got up :zzz: …)
You're marking I3 as going down the page, ie anti-clockwise in that loop, and I2 as clockwise, so they must be opposites, so it's the first one (which you had originally, in post 3 :wink:).
Personal grouch: I don't like professors who tell you to draw those circular arrows … I think it's much safer to draw arrows directly on the lines themselves … then you can easily see which currents are going the "wrong way" through any resistor, and how they add up at each junction.​
Yes, that's right. :smile:
Note that this loop equation is the sum of the other two loop equations, so it gives no new information
that's what your professor meant about only needing to use two of the loop equations!
In practice, you take a quick look at the diagram, and choose the two loops that look simplest …
in this case, I'd leave out the left-hand loop, because it has 4 items in it, while the other two loops have only 3. :wink:
  • · Replies 18 ·
  • · Replies 16 ·
18K
