Sodium light on 2 glass bars -- What's going on here?
The observation of dark concentric rings when viewing sodium light through two stacked pieces of translucent glass is attributed to thin film interference. This phenomenon occurs due to the varying thickness of the air gap between the glass pieces, leading to constructive and destructive interference of light waves. When the glass pieces are pressed together, the rings straighten and become parallel, indicating a uniform thickness. The equation 2T = (n + 1/2)λ is relevant in explaining this interference pattern. Understanding this concept can be further enhanced by researching Newton's rings.
tensor0910
This is less of a calculation and more of a observation problem:
Our teacher shined a sodium light on top of two stacked pieces of translucent glass. We then had to bend down to get eye level with the stacked glass. When we did this you could see dark ( concentric?) rings reflecting off of the glass...sort of like contour lines on a map. When we pressed the two pieces together the lines straightened out until they were all parallel. What is going on here?
[/B]
It has something to do with thin film interference...
Maybe the equation 2T = (n + 1/2 )λ is involved
[/B]
Im pretty lost here. Thanks in advance for any responses.
Likes tensor0910 and CWatters
thanks for the tip BvU. I think I got it now.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
