baron.cecil
- 8
When deriving the motions of the planets in our solar system, do we typically ignore Newton's law of gravitation between the planets themselves, since the force is negligible?
Yes.baron.cecil said:So in planetary motion, if satellites travel faster at the perigee than the apogee, that implies some change in velocity.
Both.Is it the tangential velocity that is changing, or the angular velocity?
The velocity must change in order for angular momentum and mechanical energy to be conserved. The specific angular momentum1 of the orbiting body2 isIf universal gravitation is the only force acting between the two objects, how can the velocity change?
The solar system model is derived through a combination of observations, mathematical calculations, and scientific theories. Scientists use data from telescopes, spacecraft, and other instruments to study the movements and properties of the planets, moons, and other objects in our solar system. This information is then used to develop mathematical models that accurately represent the interactions and dynamics of the solar system.
When deriving a solar system model, scientists consider the mass, density, and composition of each planet and other objects, as well as their positions and velocities relative to each other. They also take into account the laws of gravity and other physical forces that govern the behavior of celestial bodies.
Solar system models are constantly being refined and updated as new data and scientific knowledge become available. As a result, they are quite accurate at predicting the positions and movements of the planets and other objects within the solar system. However, due to the complex nature of the solar system, there may be some discrepancies between the model and the actual observations.
Yes, solar system models are commonly used to predict future events such as eclipses, planetary alignments, and the positions of comets and asteroids. However, these predictions are based on the current understanding of the solar system and may change as new data is gathered.
Yes, there are various types of solar system models, including geometric models, empirical models, and theoretical models. Geometric models use basic geometric principles to represent the positions and movements of the planets and other objects. Empirical models are based on direct observations and measurements. Theoretical models are based on scientific theories and use mathematical equations to describe the behavior of the solar system.
