Solve 2-D Spring Problem: 21.75 & 22.25 Equations
  • Thread starter Thread starter morgan82
    Spring
The discussion centers on solving a 2-D spring problem using two equations related to spring compression, with the total weight on the spring calculated at 31.25 lb. The spring constant, k, is assumed to be 5 lb/in, leading to a calculated displacement of 0.6 inches. The maximum spring compression is determined to be 6.25 inches, leaving 6.75 inches for height after accounting for the spring's original length of 13 inches. Calibration adjustments are suggested to ensure accurate measurements, and it's important to verify that the selected spring can handle the required compression without bottoming out. The calculations emphasize the need for careful consideration of spring properties in practical applications.
morgan82
http://i.imgur.com/uKydC.png
Here is the problem. I came up with two equations:
Upper Lc: 21.75=k(Lo-Lcu)
Lower Lc: 22.25=k(Lo-Lcl)
I am not sure what to do with this? How do I figure this out?
Total weight on spring = 8 + 22 + scale platform + .25 . If you use 1 lb for the platform then total = 31.25 lb. Assuming k = 5 lb/in then d = (.25 + .25) / 5 + .5 = .6 inches. Max spring compression would be 31.25 / 5 = 6.25 inches. Starting with a 13 in. long spring leaves 6.75 for h. I would expect you would need to plan some adjustment for calibration. This also assumes the chosen spring can be compressed the needed amount without bottoming out.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
