Solve Electric Diode Problem: Find I & V
  • Thread starter Thread starter Learnphysics
    Diode Electric
The discussion focuses on solving a circuit problem involving ideal diodes, where the user is tasked with finding the current (I) and voltage (V). The consensus is that if diode D2 is off, the current I is zero, leading to the conclusion that V equals 10 volts based on voltage divider equations. There is some uncertainty about the correctness of the provided solution and whether the question itself may be flawed. The user also contemplates whether to delete the thread after resolving their issue but is advised to keep it for reference. Overall, the key points revolve around diode behavior and circuit analysis using KVL/KCL principles.
Learnphysics
Find values of I and V for the circuits of figure; assuming that the diodes are ideal.
http://yfrog.com/081034op
Picture: http://img8.imageshack.us/img8/3026/1034o.png
I can use KVL/KCL.
And have a rough knowledge of finding wheather a diode is on or off using guess and check method.
The soloution given by multiple sources is assuming D1 is on and D2 is off, V=10v and I=0.
(it may be possible that the question itself is stated wrong), are these answers correct/possible?
I know current I is 0. if D2 is off (because it creates an open circuit).
but i don't understand how 10v is obtained for V...
Ah, i see We apply voltage divider equations, (New question: do i delete this thread or leave it up for anyone else to reference)
I can use KVL/KCL.
Glad you figured it out. In general, it is best to leave up your question, even if you figured it out without extra help from others. For sure you should not delete your original question if it has received responses.
