Solve F=ma Concept: Urgent Help Needed! Where Did I Go Wrong?
The discussion revolves around a student's confusion regarding the application of Newton's Second Law (F=ma) in a lab experiment involving varying hanging masses and their corresponding accelerations. The student initially calculated a slope and y-intercept from a graph of hanging weight versus acceleration but received partial credit, leading to questions about the units and relationships involved. After adjusting the graph, they sought clarification on how to predict acceleration for a new mass using the derived equation. The conversation emphasizes the need to correctly interpret the relationship between force and acceleration and to solve for acceleration algebraically based on the experiment's findings. Overall, the student is looking for guidance on resolving their calculations and understanding the underlying physics concepts.
riseofphoenix
Urgent help needed with F=ma concept! Where did I go wrong?? Help please
Use the exact values you enter to make later calculations.
A group of students performed the same "Newton's Second Law" experiment that you did in class. For this lab, assume g = 9.81 m/s2. They obtained the following results:
m1(kg) t1(s) v1(m/s) t2(s) v2(m/s)
0.050 1.2000 0.2500 1.7862 0.4123
0.100 1.2300 0.3240 1.6364 0.6502
0.150 1.1500 0.3820 1.4809 0.8067
0.200 1.1100 0.4240 1.3988 0.9511
where m1 is the value of the hanging mass (including the mass of the hanger), v1 is the average velocity and t1 is the time at which v1 is the instantaneous velocity for the first photogate, and v2 is the average velocity and t2 is the time at which v2 is the instantaneous velocity for the second photogate.
(a) Use Excel to construct a spreadsheet to do the following. (You will not submit this spreadsheet. However, the results will be needed later in this problem.)
(i) Enter the above data.
(ii) Compute the acceleration, a, for each trial.
(iii) Create a graph of the hanging weight m1g vs. the acceleration. Hint
This is what I did
(iv) Use the trendline option to draw the best fit line for the above data and determine the slope and y-intercept from it.
And then I did,
(v) report your results below.
slope = __1.045__ kg
Partial credit: Your answer received partial credit.
y-intercept = _0.2345_ N
Whatttt? What am I doing wrong??
(b) Use the information you obtained from your graph to determine the total mass of the system M = m1 + m2.
M = _1.045 kg_ Partial credit: Your answer received partial credit.
(c) Using the information you obtained in parts (a) and (b), predict what the value of the acceleration would be if the value of the hanging mass were increased to m1 = 0.40 kg.
a = ______ m/s2
You graphed force on the x-axis and acceleration on the y-axis. How can the y-intercept be in Newtons, then?
Ohhh ok...
So I switched it and got
slope - 0.956 kg
y-intercept - 0.2248 N
b. 0.956 kg
c. a = ?
How would I solve for c?
The equation of the line gives you the relationship between acceleration and force for this system. If you know one, you should be able to algebraically solve for the other.
y = 0.946a + 0.2248
ma = 0.946a + 0.2248
(0.40)a = 0.946a + 0.2248
I need help :(
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
