Solve Freefall Problem: Find Water's Depth in Well
  • Thread starter Thread starter Freeze
    Freefall
The problem involves determining the depth of a well based on the time it takes for a rock to fall and the sound of the splash to return. The total time of 2.42 seconds is divided into two parts: the time for the rock to fall (T1) and the time for the sound to travel back up (T2). The equations of motion for free fall and sound travel are combined to form a quadratic equation. Solving this equation yields the time for the rock's fall, which is then used to calculate the depth of the well. The final answer is confirmed to be 26.5 meters, matching the solution in the textbook.
Freeze
Ok I am at this problem for hours and I am still nowhere, I am just wondering if any of you can help.
Here is the question
A rock is dropped from rest into a well. If the sound of the splash is heard 2.42s later, how far below the top of the well is the surface of the water? (take the speed of sound to be 336.0 m/s and take the freefall acceleration of the rock to be 9.8 m/s^2.
So I figure ok this must mean
2.42s = Time spent falling + Amount of time it took for the sound to reach the top.
So I try to use one of the kinematic equations for motions with constant acceleration
Sf = Si + Vi*(Change of T) + 1/2 * A *(Change of T) ^ 2
Since Initial Position Si = 0 and Vi = 0 The formula will look like
Sf = 1/2 *A*(Change of T) ^ 2
Since I need to get rid of one of the unknowns I do this
Sf = 1/2 * 9.8 * (2.42s - SF/336m/s) ^ 2
Sf = 4.9 * (2.42s- SF/336m/s) ^ 2
Sf = 4.9 * (813.12m - SF)/336m/s)^ 2
And then yeah..I went further then that but let's just say it didn't give me the right answer.
I tried several other methods but nothing gave me the right answer.
Any Ideas on how to resolve this matter?
It seems that you use only one change of time but there are two times t1 fall time, t2 is time for the sound to get back up. And t1+t2=2.42
For the distance we know that S=0,5g*t1 but also S=Vsound*t2 and
t2=2.42-t1
So now you can make youre square equation with standard solutions.
Sorry, I have been out of school for one year, and I now have no idea how to make square equation with standard solutions.
Can you provide an example please?
come on guys, I really need some help here.
Here's how I would do it.
Let T1 = time for rock to fall
Let T2 = time for sound to reach you
We know from freefall :
X = (1/2) a T^2
so
X = (1/2) a (T1)^2
Then from the sound reaching you we have:
X = Velocity * Time
X = V*T2
combine that with first as X=X
V*T2 = (1/2) a * (T1)^2
We also know T1+T2 = 2.42 seconds
T2 = 2.42 - T1
so
336*(2.42-T1) = (1/2)*9.8*(T1)^2
Write as a quadratic equation :
(multiply things out, then get T1^2 alone, etc.
T1^2 + 68.6 T1 - 165.9 = 0
Use solution of quadratic equations to get Ti, then plub into x=(1/2)(9.8)T1^2 to get X. (search google if you don't know solution of quadratic).
thats how I would do it.
I get 26.5 meters.
Wow, you gave a really easy to follow explanation and that answer matches with the answer from the back of the book as well.
Thank you very much.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
