Solve Gauss's Law and Flux: 55.3M Excess Electrons
The discussion centers on calculating the net electric flux through a closed surface containing 55.3 million excess electrons. The key equation used is Φ = Qin/ε, where Qin represents the enclosed charge and ε is the permittivity constant (8.85 x 10^-12 F/m). Participants clarify that the excess electrons indicate a negative charge, which should be considered in the calculation of Qin. The solution involves multiplying the number of excess electrons by the elementary charge (-1.60 x 10^-19 C) to find Qin. The problem is ultimately resolved by applying the correct formula, demonstrating that the solution can be simpler than initially perceived.
dals2002
[SOLVED] Gauss's Law and Flux
ok so i have the biggest question of all i tried solving the following problem:
55.3 million excess electrons are inside a closed surface. What is the net electric flux through the surface?
now i tried the following equations:
\Phi= E . A = Qin/\epsilon
but i have the biggest question when there is excess electron does it mean that the electron field is negative, and if it does then that goes in Qin where then \Phi would be equal to Qin/\epsilon, and epsilon being 8.85*10 (permittivity constant)
well any help in solving this problem is very grateful
You can solve for the enclosed charge, since the elementary charge of an electron (-1.60*10^-19 C) and the number of electrons is known. Just use Q/epsilon to solve for flux.
oh wow that was easy, i always see things harder then they are, thanks terbum
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
