Solve Log Equations with Log Laws: Examples on Logbase 4, 2, and 10
  • Thread starter Thread starter skg94
    Log
The discussion focuses on solving logarithmic equations using log laws, with specific examples involving bases 4, 2, and 10. Participants express confusion about the correct steps to isolate x in various equations, particularly in manipulating logarithmic expressions. Suggestions include correctly applying log properties to eliminate logs and transforming equations into quadratic forms. There is also a side conversation about the reliability of one participant's contributions, highlighting the occasional mistakes made in problem-solving. Overall, the thread emphasizes the importance of understanding logarithmic functions and their inverses in solving these types of equations.
skg94
Solve for x
logbase 4 for question 1.
1. log (x+2) - log (x-4) =1/2
log base 2:
2. log (3x+1) = 2 - log (x-1)
log base 10:
3. log sq root (x^2 -21x) =1
similar just different numbers..
log (x-4) - log (x+2) =4 base 2
log (x-4)=4-log(x+2)
log (x^2-2x)^7=21
Log laws
1. log (x+2)/(x-4) = 1/2 - is that right or is it log (x+2) = 1/2 + log (x-4) then cancel the logs. I don't know. When i tried it both didnt work. Maybe i calculated it wrong if its set up right.
2. (3x+1)(x-1) = 2
3x^2-2x-1=2
3x^2-2x-3 - what do i do from here?
3. If you square both sides, or times the square and x by .5 and equal it to zero, i don't know what to do, same process of solving for the later 3 I am pretty sure I am having difficulty with these.
Any help please
1. log (x+2)/(x-4) = 1/2 looks fine. Next step: get rid of the log.
2. (3x+1)(x-1) = 2 -- Here you did just that, i.e. got rid of the log, but only on the left side. You need to fix the right side before you work out (3x+1)(x-1)
3. log( √ something ) = something else ... get rid of the log first:
√ something = 10 ^ (something else) ... square each side:
something = (10 ^ (something else)) ^ 2 = 10 ^ (2 times something else)
This is a quadratic equation which you should be able to solve. (Hint: the number 29 should appear somewhere on the way. If you see that, you're probably getting on okay.)
Are you clear on what a logarithm is? It is the inverse to the exponential function- if y= loga(x), then x= ay. So if log4 A= 1/2, then 1/2= 4A. What A makes that true?
Try again.
If log4 A = 1/2, then A = 41/2...
Oops!:redface:
i got them all ha it was just simple as getting rid of the log, silly we all do have our days.. thank to all of you though
Mark44 said:
We all have our days ...
Halls seems to have her bad days more often than not!
I would disagree on two points:
1. I have rarely seen him make a mistake.
2. Halls is a "he".
2. Halls is a "he".
Ok, I would disagree on just the one point. For some reason, I thought HoI was a she.
But I haven't got enough fingers on both hands to count how many errors he's made in the last month or two! (Ok, maybe that's a bit harsh, but for a "PF MENTOR", far more than enough.)
