Solve Mesh Analysis Problem: Use Super Mesh?
The discussion revolves around solving a circuit analysis problem using mesh analysis, with a focus on whether to apply super mesh techniques or consider alternative methods such as nodal analysis. Participants are seeking guidance on the appropriate approach to take in this context.
  • Homework-related
  • One participant expresses uncertainty about the technique to use for solving the circuit, questioning whether super mesh analysis is appropriate.
  • Another participant suggests that nodal analysis could be a viable alternative, specifically mentioning the top three nodes of the circuit.
  • A third participant explains the concept of supermesh in detail, describing how to combine meshes that share a current source and outlining the application of Kirchhoff's Voltage Law (KVL) and Kirchhoff's Current Law (KCL) in this context.
  • This participant also references a textbook for further information on network analysis, indicating that their explanation is based on material from that source.
There is no consensus on the best approach to solve the problem, as participants propose different methods (mesh analysis with super mesh versus nodal analysis) without agreeing on a single solution.
The discussion does not clarify specific assumptions about the circuit configuration or the nature of the dependent and independent sources involved, which may affect the choice of analysis technique.
shaiqbashir
Hi Guys!
well! i have made my all efforts in solving this circuit please help me.
WHat technique should i use?
Super mesh? or what?
Plz help me
Same problem. Attachment is Pending Approval. Is it too big maybe?
Do you have to do it with mesh analysis? I would do nodal analysis on the top 3 nodes.
Alright, what you have in this circuit is I2 an independent current source and I1 a dependent Voltage controlled current source (VCCS).
In mesh analysis with current sources a special case arises when two meshes have a (dependent or independent) current source in common this case is called a "supermesh".
In a supermesh you must combine the meshes that the current source is shared in, creating alarger one. If a circuit has two or more supermeshes they should be combined to form a larger supermesh.
In this case your suprmesh is the three meshes in which I2 and I1 are a part of. Apply KVL to the whole loop of the supermesh. Then use KCL to find the relationships between your currents (from KVL), you must do this because no known voltage sources are known.
I would show you some of my work but I do not know how far you have gotten and wouldn't want to spoil the learning process for you (lmao)!
*Info paraphrased from "Fundamentals of Electric Circuits" 2nd edt. Alexander-Sadiku p.96*
Check their webpage out at:
http://highered.mcgraw-hill.com/sit...iew0/chapter3/network_analysis_tutorials.html
This contains network analysis tutorials that helped me out when I took this subject.
Good Luck!
  • · Replies 28 ·
  • · Replies 17 ·
