Solve "Moments of Force" with Uniform Meter Rule & Pulley
  • Thread starter Thread starter look416
    Force Moments
The discussion focuses on solving a physics problem involving a uniform meter rule supported by a knife-edge and a pulley system. Participants analyze the forces and moments acting on the system, particularly the placement of a 50 g mass to achieve balance. Confusion arises regarding the calculation of the reaction force (R) and the inclusion of various forces in the moment equations. It is suggested that taking moments about the knife-edge simplifies the problem, eliminating the need to calculate R directly. The key takeaway is that the position of the 50 g mass is crucial for balancing the rule, and moments can be taken about any point for analysis.
look416
A uniform metre rule of mass 100 g is supported by a knife-edge at the 40 cm mark and a string at the 100 cm mark. The string passes round a frictionless pulley and carries a mass of 20 g as shown in the diagram.
At which mark on the rule must a 50 g mass be suspended so that the rule balances?
using the \sum F=0
therefore, R at the knife-edge + T at the 100 cm = W
R = 0.8
then take the moment at the c.g, which is at 0.5
therefore R(z)=T(50)
in the end,what i got is z=0.3125
where T=0.5N
wrong again...
Hi look416! :smile:
(have a sigma: ∑ :wink:)
I don't understand what you've done …
there should be moments of three forces …
and where does T = 0.5N come from? :confused:
(btw, no need to convert to N … they're all weights, so just use the masses :wink:)
lolz
maybe I am not good in explaining XD
anyway
if i take the head of the ruler as the moment
which means
RX + 50(100) = 50(100)
which results in RX = 0
T = 0.5N is because the question demand for the X cm when the load is 50g
for 50g x 10 x 10^-3 = 0.5N
uhh? :redface: where's the 40cm? where's the 20g? and what's R? :confused:
so, i have to find the value of R by taking moments as the head of the ruler
if so,
R(40)+20(100)=50(100)
R=75g
then??
Is R the reaction force at the knife-edge?
If so, you don't find it by taking moments, you find it by adding the vertical components of force to zero …
which I thought you'd already done, and found it was 80g (weight) ??
You haven't included the 50 g mass in this moments equation. :confused:
(btw, if you take moments about the knife-edge you won't need to find R anyway)
but there said at which mark on the rule must a 50 g mass be suspended so that the rule balances?
so shouldn't i have to included the knife edge in my calculation?
not taking it as the moments ...
(i wish you wouldn't say "taking it as the moments" … you take moments of forces about a point :wink:)
Yes, the 50g mass, and its unknown position, must be included (unless you take moments about that position).
You can take moments about any point …
it can be either end of the ruler, or the knife-edge, or the point where the 50g is, or indeed anywhere else, either on or off the ruler.
But in this case it's easier to use the knife-edge, since that avoids working out the reaction force, R. :smile:
9K
