Solve SAT Math Question: \frac{x}{t} with x and t Positive
  • Thread starter Thread starter JBD2
    Sat Sat math
The problem involves solving the equation \(\sqrt{x^{2}-t^{2}}=2t-x\) for the ratio \(\frac{x}{t}\), where \(x\) and \(t\) are positive numbers. Participants are exploring the implications of this equation and how to manipulate it to find the desired ratio.
  • Participants discuss various algebraic manipulations of the equation, including squaring both sides and dividing by terms involving \(t^2\). There are questions about the correctness of earlier steps and the implications of dividing by \(t^2\) when \(t\) cannot be zero.
The discussion is ongoing, with participants providing guidance on how to proceed with the algebraic manipulation. Some express uncertainty about earlier steps and the implications of certain assumptions, while others clarify the correct approach to isolating \(\frac{x}{t}\).
Participants note that both \(x\) and \(t\) must be positive, which influences the validity of certain steps in the algebraic process. There is also a recognition that \(t\) cannot equal zero, which is crucial for the discussion.
JBD2
[tex]\sqrt{x^{2}-t^{2}}=2t-x[/tex]
If x and t are positive numbers that satisfy the equation above, what is the value of [tex]\frac{x}{t}[/tex]?
2. The attempt at a solution
[tex]x^{2}-t^{2}=4t^{2}-x^{2}[/tex]
[tex]x^{2}+x^{2}=4t^{2}+t^{2}[/tex]
[tex]2x^{2}=5t^{2}[/tex]
I'm unsure of what to do next.
Divide both sides of the equation by [itex]2t^2[/itex] and then take the square root.
Do you mean divide:
[tex]2x^{2}=5t^{2}[/tex] by [tex]2t^{2}[/tex]? How does that work?
Yes, dividing both sides of the equation gives you:
[tex]\frac{2x^2}{2t^2}=\frac{5t^2}{2t^2} \Rightarrow \frac{x^2}{t^2}=\frac{5}{2}[/tex]
Then take the square root of both sides of the equation, that should give you x/t=...
The answer is apparently [tex]\frac{5}{4}[/tex] though, and I don't understand where the 2t² comes from.
Divide by [tex]2 t^2[/tex] to create an equation in which one side is constant, the other involving only [tex]x \text{ and } t[/tex].
How do I get 5/4 then?
I'm not sure, because looking back at your earlier posts (which I didn't do the first time) I think you have an early error.
Here is your original equation.
[tex] \sqrt{x^{2}-t^{2}}=2t-x[/tex]
Notice that we cannot have [tex]x = 0[/tex], since [tex]\sqrt{-t^2}[/tex] is not a real number. Since you want the value of [tex]x/t[/tex] we don't need to consider [tex]t = 0[/tex] either.
The first step in the solution is to square each side.
[tex] x^2 - t^2 = \left(2t-x\right)^2 = 4t^2 - 4xt + x^2[/tex]
The right hand side on your first step of the solution is only
[tex] 4t^2 - x^2[/tex]
which isn't correct, since
[tex] (2t-x)^2 \ne 4t^2 -x^2[/tex]
Continuing on with the work,
[tex] \begin{align*}<br /> x^2 - t^2 & = 4t^2 - 4xt + x^2 \\<br /> -t^2 & = 4t^2 - 4xt \\<br /> -5t^2 & = -4xt <br /> \end{align*}[/tex]
Remembering you want to reach a point in which you have [tex]x/t[/tex] on one side,
and a constant on the other, what do you need to do to the final equation here to reach it? (It is at this point that knowing [tex]t[/tex] cannot equal zero is important.)
[tex]-5 = \frac{-4x}{t}[/tex]
[tex]\frac{5}{4} = \frac{x}{t}[/tex]
Oh ok I get it now, thanks so much.
  • · Replies 24 ·
