Solve Tricky Word Problem: Motorcycle Cop & Red Ferrari 308 GTS
  • Thread starter Thread starter kurtrudviking
    Word problem
The discussion revolves around solving a physics problem involving a motorcycle cop and a woman in a Ferrari. The cop has a 2-second delay before starting his pursuit and must catch the Ferrari, which is traveling at 90 km/h, over a distance of 2 km. Key calculations include converting speeds to meters per second and determining the time available for the cop to catch up after accounting for his delay. The solution involves setting up equations for the cop's acceleration and maximum speed to find the required average acceleration. Participants express appreciation for the collaborative problem-solving approach, highlighting the clarity gained from shared insights.
kurtrudviking
A motorcycle cop, parked on the side of a highway is passed by a woman in a red Ferrari 308 GTS doing 90km/h. After a few attempts to get his cycle started, the officer roars off 2.00s later. At what average rate must he accelerate if 110km/hr is the top speed and he is to catch her just at the state line 2.00km away?
I first started this question by showing what i know and making all unit conversions i need to.
1)
Cop for first 2 sec
vi= 0 km/hr
Pi=0 m
a=0
Ti= 0
Tf= 2
Cop after 2 sec
vi= 0 km/hr
vf= 110 km/hr
pf= 2000 m or 2 km
Ti= 2
a= X
Woman
vi= 90 km/hr
Pi= o m
a= 0
Tf=2
2) Convert the km/hr into m/s
(110 km/hr) X (1000 m/hr) X (1/60 Min) X (1/60 Sec) = 30.56 m/s (COP)
(90 km/hr) X (1000 m/hr) X (1/60 Min) X (1/60 Sec) = 25 m/s (woman)
3) Then find out how long it takes the Woman to get to the state line.
Woman
Position Final = Vi(T)
2000m = 25(T)
T = 80 sec
4) This means that the cop has 78 sec to catch her because it takes him 2 sec to start his bike.
thats all i got...
We had a problem exactly like this in AP Physics my Sr. year. If I remember correctly your best bet is to find the womans condition after 2 seconds. Now use some algebra, and a constant acceleration equation (one with all variables x, v, a,) and set them equal, by either t or X it is your choice, however think about which will cancel out better. and you can use the border (or the limit as you approach it) as your final displacement.
Although the best answer is truly it doesn't matter, because it will take longer to solve the problem than to write the ticket. :)
thanks so much! much appreciated if anyone was curious this is how i ended up solving it.
Women Max = 25 m/s
Cop Max = 30.5 m/s
amount of time available
2000 m/25 m/s = 80 s - 2 s = 78 s
.5(a)(t1)^2 + 30.5(t2) = 2000 m
t1 + t2 = 78 s
a(t1) = 30.5
.5(30.5)(t1) + 30.5(78 - t1) = 2000
15.25(t1) + 30.5(78) - 30.5(t1) = 2000
t1 = (2000 - 30.5(78)) / (15.25 - 30.5) = 25.137 sec
a = 30.5 / 25.137 = 1.216 m/s^2
This problem isn't all that tricky.
You have the first step already, which is determining the time budget. At 25 m/s the 2000 m can be covered in 80 seconds less the 2 second head start ... so 78 s.
Now look at the cop's velocity as a function of time.
There is an acceleration time call it T1 and time T2 at max speed.
You know his Vmax and you know for uniform acceleration his Vavg during acceleration will be half Vmax
To arrive at the Ferrari in 2 km then his distance traveled will need to be
2000 = 1/2*Vmax*T1 + Vmax*T2
won't it? And you already know T1 + T2 = 78
... so 2 equations and 2 unks.
thanks man both you guys helped me a ton :)
now that you guys showed me this it makes total sense and i can't believe i didnt think of it before. have a great day guys
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
