Solve u = 2x - 3y & v = -x + y in terms of u & v, then find Jacobian.
  • Thread starter Thread starter VinnyCee
    Jacobian Terms
The discussion focuses on solving the equations u = 2x - 3y and v = -x + y for x and y in terms of u and v, resulting in y = -u - 2v and x = -u - 3v. The Jacobian is calculated, with initial claims of -2 being disputed, as the correct approach yields a Jacobian of -2 based on partial derivatives. The transformation of the boundaries of a parallelogram in the xy-plane to the uv-plane is explored, revealing that the boundaries do not convert to simple constant equations in u or v. The participants express confusion about the next steps, particularly regarding the integration process and how to proceed with the transformed coordinates.
VinnyCee
Solve u = 2x - 3y & v = -x + y in terms of x & y, then find Jacobian.
Here is the problem:
Solve the system u = 2x\;-\;3y,\;\;v = -x\;+\;y for x and y in terms of u and v. Then find the Jacobian \frac{\partial\left(x,\;y\right)}{\partial\left(u,\;v\right)}.
Find the image under the trasformation u = 2x\;-\;3y,\;\;v = -x\;+\;y of the parallelogram R in the xy-plane with boundries x = -3,\;\;x = 0,\;\;y = x\;and\;y = x\;+\;1
Here is what I have:
y = -u\;-\;2v\;and\;x = -u\;-\;3v I am not sure of these answers.
Assuming those are correct, I get the Jacobian to be -2. This is where I am stuck, how do I do the second part? I can get the v-values to be 0\;and\;1 here,
y = x\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;y = x\;+\;1
-2v\;-\;u = -3v\;-\;u\;\;\;\;\;-2v\;-\;u = -3v\;-\;u\;+\;1
v = 0\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;v = 1
But when I try and do the last part for the u values, I get u = u\;+\;3, which is impossible becaus then 0 = 3.
Please help!
Did anyone check these?
Please, this is the last problem and probably the toughest. Thank you all in advance.
Yes, you solved correctly for x and y, but the Jacobian is NOT -2. How did you get that?
"Find the image under the trasformation of the parallelogram in the xy-plane with boundries x = -3,\;\;x = 0,\;\;y = x\;and\;y = x\;+\;1."
The boundaries do NOT neccessarily convert to "u= constant" or "v= constant".
The line x= -3, y anything, converts to u= 2(-3)-3y, v= -(-3)+ y= 3+ y so y= v- 3.
Then u= -6- 3(v- 3)= -6- 3v+ 9= -3v+ 3. One boundary is u= -3v+ 3.
The line x= 0 converts to u= 2(0)- 3y, v= -(0)+ y so y= v. Then u= -3(v).
Another boundary is u= -3v. (Which is, of course, parallel to the previous line.)
The line y= x converts to u= 2x- 3(x)= -x, v= -x+ (x)= 0. One boundary is v= 0.
(Since x can be anything, u can be anything.)
The line y= x+1 converts to u= 2x-3(x+1)= 2x-3x- 3= -x- 3, v= -x+ (x+1)= 1.
The last boundary is v= 1 (since x can be anything, u can be anything). That line is, of course, parallel to v= 0.
How I got the Jacobian
I used
\frac{\partial x}{\partial u}\;\frac{\partial y}{\partial v}\;-\;\frac{\partial y}{\partial u}\;\frac{\partial x}{\partial v}
with the earlier equations solved for x and y and got
(-1)(-1) - (-1)(-3) = 1 - 3 = -2
What do I do now? put the limits into an integral with what as the integrand? Rectangular, cylindrical of spherical?
so \frac{\partial y}{\partial x}= -2, not -1!
I don't know! What does the problem ask? Your original post just said "solve for x, y, find the Jacobian, find what a parallelogram would be in the "u,v" coordinate system". You didn't say anything about an integral!
I presume you are to do whatever integral you are given in uv- coordinates- that's not any of those!
