Thanks, this post helped a lot.
Just to be sure, when you integrated the RHS. The t came from the integration of -g/b^2 as two numbers, and not from the dt on the right? I think this is correct as if I differentiated -(g/b^2)t i would get -(g/b^2)
I get confused with the notation dy/dx, as I am constantly told it is one symbol, it is not to be treated as dy over dx. Then I see in some cases it can be moved around, but apparently only if doing so enables you to eliminate it later.
The expression on the LHS is not so tough now I see it before me, the integral of dv must be 1, leaving 1/(v^2 + b^2) which is there is a standard integral for.
This leaves me wondering only why there is no constant of integration on the LHS.
I also don't follow this bit
HallsofIvy said:
\frac{1}{b^2}(arctan(v/b)- arctan(v_0/b))= -\frac{g}{b^2}t
I got instead
\frac{1}{b}(arctan(v/b)- arctan(v_0/b))= -\frac{g}{b^2}t
Please let me know if this is the correct way of seeing it! :)
The last part of the question is
By writing a = v dv/dx, solve the resulting differential equation
and determine the height above the point of projection at time t
in terms of v, b, g and v0.
I do not understand the notation here. They ask for the position, so I assume this is the second derivative of the acceleration expression, or the derivative of the velocity expression. Why is it multiplied by v?
