Solving a Football Kicking Problem with PreCalc
  • Thread starter Thread starter mandomansion
    Precalc
The discussion revolves around a projectile motion problem involving a football kicked at a specific angle and initial velocity. The participants are tasked with modeling the motion using equations and determining various characteristics of the ball's flight.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive the equations of motion for the football based on given parameters. Some participants question the value of gravitational acceleration used in the calculations, noting the importance of unit consistency.
Participants are actively engaging with the problem, with some providing clarifications regarding the gravitational constant appropriate for the units in use. There is a collaborative effort to correct assumptions and refine the calculations, although no consensus on the final answers has been reached.
The original poster expresses urgency due to impending test consequences and mentions a potential error in posting in the wrong forum. There is also a request for guidance on calculator settings relevant to solving the problem.
mandomansion
Scott kicked a football with an initial velocity of 50 ft/sec at an angle of 65 degrees with the horizontal and at a height of 3 feet. Write the equations that would model this situation and answer the following:
a)
x(t) = _____________ (fill in formula with variable values plugged in)
y(t) = _____________ (fill in formula with variable values plugged in)
b) What is the max height of the ball?
c) How far did the ball land from Scott?
d) How long was the ball in the air?
Calculator problem if that wasn't obvious enough.
Formulas:
x(t) = (V * cos x)t
y(t) = -0.5gt^2 + (V * sin x)t + h
My attempts: (which are wrong by the way)
a)
x(t) = (50 * cos 65)t [CORRECT]
y(t) = -0.5(9.8)t^2 + (50 * sin 65)t + 3 [ITALICIZED PART IS WRONG; I figured g stood for gravity, so 9.8, right?]
b)
107.694 ft (didn't get formula right, and probably didn't use calculator correctly, so these are probably far off)
c)
190.178 ft.
d)
Didn't have enough time to finish.
This is a pretty quick PreCalc problem if you know what you're doing (which I didn't), so it would really help if one could do this.
And if one could tell me what mode settings my TI-83 should be on when I do this, I'd appreciate it.
And I apologize; in my 1AM rush to figure this problem out so I don't get another 10 points off on another test, I posted this in the wrong forum.
You were right in thinking that g stood for gravity, it simply is a matter of units. 9.8 represents the acceleration in m/s^2, whereas you're working with feet in this problem!
Bah, so what would the correct # be?
32 right?
Right.
Thank you very much. My test grades will finally get the justice they deserve.
  • · Replies 38 ·
