Solving a Multimeter Problem with 10k Internal Resistance
  • Thread starter Thread starter scientifico
    Multimeter
A multimeter with a 20,000 ohms per volt specification will affect the measurement of a 1-volt source with a 10k internal resistance. When calculating the total resistance in the circuit, the voltmeter's resistance in series with the source results in a combined resistance of 30k ohms. Using Ohm's Law (V = IR), the reading on the multimeter can be determined. High resistance in a multimeter is beneficial as it minimizes the current drawn from the circuit, allowing for a more accurate measurement. Understanding this concept is crucial for effective use of multimeters in electronics.
scientifico
Hello, I'm trying to learn some electronics by myself but it's quite difficult, now I'm studying the multimeters and a problem says
What will a 20000Ω/V meter read on its 1 volt scale, when attached to a 1 volt source with an internal resistance of 10k?
Can you set up this problem for me because I didn't yet understood well the argument. Thank you!
Analog meters have an ohms per volt spec. This means that if the meter a 20,000 ohms per volt spec and has a 10 volt range that means that the load the probes will put on a circuit while in the 10 volt range would be 200,000 ohms. So do the math figuring a series circuit of 10K ohms with 200K ohms and a 1 volt source.
It is equivalent to having the voltmeter in series with a resistance R1 of 10k and another R2 of 20k.
Use V = IR to find V2 which is the reading of the voltmeter.
But doesn't an high resistance mean a lower sensibility (because it "resist" to more electrons)? Instead why it's the opposite here?
I don't understand what you just said, but here's the thing: high resistance in a meter means the meter will have less effect on the circuit that it is measuring because it will draw less current out of it. That's a good thing.
