Solving a Physics Homework Problem: Rocket Mass and Acceleration
To determine the amount of gas a rocket must eject to achieve an initial acceleration of 25.0 m/s², the total force can be calculated using F=ma, where the mass is 6000 kg. The impulse-momentum theorem is applicable for calculating the required mass loss in the first second, considering the significant impact of mass loss on acceleration. The problem's phrasing is deemed ambiguous, with a preference for interpreting it as needing a constant acceleration of 25.0 m/s² during that time. The rocket equation, v = v_ex ln(m_0/m), is essential for solving this problem, utilizing known values for velocity, exhaust velocity, and initial mass. Understanding these principles is crucial for accurately solving the physics homework problem.
iamwilson
A rocket is fired in deep space, where gravity is negligible
If the rocket has an initial mass of 6000kg and ejects gas at a relative velocity of magnitude 2000m/s , how much gas must it eject in the first second to have an initial acceleration of 25.0m/s^2 ?
im stuck on this problem, can anyone help me on it thanks!
You can figure out the total force using F=ma
Then you can use the impulse-momentum theorem to calculate the amount of fuel needed to be ejected in the first second.
the mass loss of the rocket is big enough to be significant, given the fact that the
acceleration was given with 3 significant digits.
Given this, it think "how much gas must it eject in the first second to have an initial acceleration of 25.0m/s^2" is ambiguous.
I think "how much gas must it eject in the first second to have a constant acceleration of
25.0m/s^2 during this time" is the most reasonable interpretation.
You will need the rocket equation v = v_ex ln(m_0/m) that you gave in your other post for this. you know v, v_ex and m_0 (initial mass of the spaceship).
sorry, this is my first time using this website, so i don't know all the rules, but it's is extremely helpful
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
