Solving a Series Convergence Problem: Can You Help?
The discussion revolves around solving the convergence of the series ∑(−3)^n / 7^n from n=1 to infinity. The user initially attempts to derive the sum but struggles with finding a general form for s_n and considers using a recurrence relation. They later realize that the series can be treated as an alternating series and confirm that the geometric series formula can be applied. Ultimately, the user finds clarity in their approach after consulting their textbook. The conversation highlights the importance of recognizing series types and applying appropriate convergence tests.
Benny
Hi, I'm having trouble getting the sum of the following series. I'm pretty sure that it is convergent.
<br /> \sum\limits_{n = 1}^\infty {\frac{{\left( { - 3} \right)^n }}{{7^n }}} <br />
Here is what I have done.
<br /> \sum\limits_{n = 1}^\infty {\frac{{\left( { - 3} \right)^n }}{{7^n }}} = - \frac{3}{7} + \frac{9}{{49}} - \frac{{27}}{{343}} + ...<br />
<br /> s_1 = - \frac{3}{7},s_2 = - \frac{{12}}{{49}},s_3 = - \frac{{111}}{{343}}<br />
The sum seems to be heading towards a negative number.
I think I need to deduce a general form for s_n and then take the limit as n goes to infinity. I'm having trouble with this. I've only been able to come up with:
<br /> s_n = \frac{{\left( { - 1} \right)\left( {something + ve} \right)}}{{7^n }}<br />
I've decided to take a slightly different approach to this.
<br /> s_n = \frac{{7\left( {7^{n - 1} s_{n - 1} } \right) - 3^n }}{{7^n}} = s_{n - 1} - \left( {\frac{3}{7}} \right)^n <br />
<br /> s_n = s_{n - 2} - \left( {\frac{3}{7}} \right)^{n - 1} - \left( {\frac{3}{7}} \right)^n <br />
<br /> s_n = s_0 - \sum\limits_{k = 1}^n {\left( {\frac{3}{7}} \right)} ^k <br />
<br /> \sum\limits_{n = 1}^\infty {\frac{{\left( { - 3} \right)^n }}{{7^n }}} = \mathop {\lim }\limits_{n \to \infty } s_n = - \frac{3}{7} - \sum\limits_{k = 1}^\infty {\left( {\frac{3}{7}} \right)} ^k = - \frac{3}{7} - \left( {\frac{{\frac{3}{7}}}{{1 - \frac{3}{7}}}} \right) = - \frac{{33}}{{28}}<br />
Ok well that's my clumsy attempt. Surely there must be an easier way than needing to solve a recurrence relation. Any help appreciated.(I don't have the answer)
geometric series
if |x|<1
\sum_{k=n}^\infty x^k=\frac{x^n}{1-x}
Thanks for your response lurflurf. The series I've got looks like an alternating series so can I just use that formula? I'm probably not seeing something very obvious but any further assistance would be good thanks.
Edit: Nevermind, I checked my book and it appears that I can apply that formula. Thanks again for the help.
\sum_{k=n}^\infty x^k=\frac{1}{1-x} for |x| < 1.
