Solving complex number equations
The discussion focuses on solving the equation (z^4-2+i)(z^2+1-i)=0, specifically using the quadratic formula for the term (z^2+1-i)=0. The correct coefficients are clarified as a=1, b=0, and c=1-i, rather than the initially suggested values. It is noted that using the quadratic formula is unnecessary since the equation can be simplified to z^2=-1+i, allowing for direct square root calculation. The conversation also emphasizes the importance of converting complex numbers to polar form for easier manipulation, particularly when finding roots. The final takeaway is the application of DeMoivre's theorem for calculating square roots in both polar and Cartesian forms.
deryk
Hello, I am trying to solve
With the quadratic formula:
(z^2+1-i)=0
Does a=1, b=1 & c=-1?
Thanks for your time.
IM meant to
(a) Give answers in polar form using the principal argument;
(b) Give answers in cartesian form
Cartesian is (x,y) is it not and polar is (r,theta) I am just not sure about the principal argument.
No, a=1, b=0, and c=(1-i) because "a" is the coefficient of z^2, "b" is the coefficient of z and "c" is the constant term.
(z^2+1-i)=0
IM meant to
To answer your questin a= 1, b= 1, and c= -i.
However, there is no reason to use the quadratic formula here- since
z2+ 1-i= 0, z2= -1+ i and you just take the square root (this is what the quadratic formula would give you anyway):
z= \sqrt{-1+ i}
You'll want to convert that into polar form to take the square root. The answer will then be in polar form and you will need to convert back to Cartesian form.
The polar form of a+ bi is reθi where
r= sqrt{a^2+ b^2} and \theta= tan^{-1}(\frac{b}{a}).
z= \sqrt{-1+ i}
How would you write z=+ or -(-1+i)^0.5 & z= + or - (2-i)^0.5 in polar and cartesian form? Thanks.
Pretend the complex number under the radicand is a 2-dimensional position vector with components (-1,1) in the case of the first one. Get the argument (angle from the positive real axis) and modulus (magnitude of the vector) from that, then write it in polar form to get the roots.
Since you copied the formulas I gave for converting from cartesian to polar coordinates, I assume you are asking about the square root:
DeMoivre's formula: If a complex number has "polar coordinates" r, θ (in other words, the number can be written r(cos θ+ i sin θ) or re) then it's square roots are
r^{\frac{1}{2}}(cos\frac{\theta}{2}+ i sin\frac{\theta}{2})
and
r^{\rac{1}{2}}(cos(\frac{\theta}{2}+ \pi)+ i sin(\frac{\theta}{2}+\pi))
or
r^{\frac{1}{2}}e^{\frac{\theta}{2}}
and
r^{\frac{1}{2}}e^{(\frac{\theta}{2}+\pi)}
