Simplifying (▲^2 - x▲)(x^3) Using Finite Differences
The discussion centers on simplifying the expression (▲^2 - x▲)(x^3) using finite differences. The initial steps involve breaking down the expression into components, but the proposed solution is ultimately deemed incorrect. The correct approach involves recognizing that Δ2x^3 simplifies to 6x + 6. Additionally, there is a note about the need for an extra parenthesis in the expression for clarity. The conversation emphasizes the importance of careful simplification in mathematical expressions.
irony of truth
I am finding (▲^2 - x▲)(x^3).
I hope I am correct here...
(▲^2 - x▲)(x^3) = ▲^2(x^3) - x▲(x^3)
= ▲▲(x^3) - x( (x+1)^3 - x^3 )
= ▲( (x+1)^3 - x^3 ) - x( (x+1)^3 - x^3 )
= (x+2)^3 - (x + 1)^3 - (x+1)^3 + x^3 )
Is my solution correct?
No. Δ2x3 IS Δ(Δ x3)= Δ((x+1)3- x3)= Δ(3x2+ 3x+ 1)=
3(x+1)2+ 3(x+1)+ 1- (3x2+ 3x+ 1)= 6x+ 6.
The work looks right, but you had really ought to simplify the expression. (Oh, and you need to stick an extra parenthesis in front)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
