Solving for a Hypotenuse: A Frustrating Problem for Morgan
  • Thread starter Thread starter rockmorg
To solve for the hypotenuse in a right triangle with an angle of 70 degrees and an adjacent leg of 7500, the cosine function is correctly set up as cos(70) = 7500/y. To isolate y, multiply both sides by y, resulting in y*cos(70) = 7500, and then solve for y. The confusion arose from comparing this problem to a different one, but the approach remains consistent across similar equations. Understanding the manipulation of equations clarifies the solution process.
rockmorg
Hey all -
I'm going insane because I can't think of how to do this...
I can't for the life of me get this straight... I have a triangle that I'm trying to solve for the hypotenuse, angle theta is 70 degrees and I know the adjacent leg is 7500. Cosine SHOULD solve for the hypotenuse, right (adjacent/hypotenuse)? I can't get it to solve for the hypotenuse.
I set it up like this:
cos70 = 7500/y
I need to get the 7500 on the side with the cos70, but wouldn't I have to multiply the right by 1/7500 to cancel it on that side for y (hypotenuse)?
Any help would be appreciated, I'm running into this over and over with my probelms.
Thanks!
Morgan
Just invert both sides:
1/cos 70 = y/7500
then solve for y
I have to be missing something... because there is a similar problem where they basically (diff. numbers) make it (7500)cos70 = y
I'm no expert but I did it like this..
cos70 = 7500/x x= hypot
cos70 = .3420
.3420 = 7500 /x
.3420x = 7500
x = 7500 / .3420
x = 21929.82456
rockmorg said:
Hey all -
cos70 = 7500/y
Thanks!
Morgan
OK
Here's another approach:
You have it set up correctly.
Multiply both sides by y to get the y out of the denominator on the RHS:
y*cos 70 = 7500
then solve for y.
The "similar problem" is not the same as this one. This is just a couple of fractions that are making your head hurt. Think about how you would solve this:
2 = 1/x
you can either take the inverse of both sides to get
1/2 = x
or you can multiply both sides by x to get
2x = 1
and then solve for x.
It's the exact same result.
hope this helps.
hmmm okay I'm seeing it is not the same as the other problem that I thought was the same... so your answers make sense.
thanks guys!
