Solving for a Hypotenuse: A Frustrating Problem for Morgan
  • Thread starter Thread starter rockmorg
The discussion revolves around solving for the hypotenuse of a right triangle given an angle and the length of the adjacent side. The angle theta is 70 degrees, and the adjacent leg measures 7500 units. Participants explore the use of the cosine function in this context.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the setup of the cosine function and the manipulation of the equation to isolate the hypotenuse. There are attempts to clarify the correct approach to rearranging the equation and questions about the relationship between different problems.
Some participants provide guidance on how to manipulate the equation correctly, while others express confusion about the differences between this problem and similar ones they have encountered. The discussion reflects a mix of understanding and uncertainty, with no explicit consensus reached.
Participants note the potential for confusion due to similar problems and the specific values involved. There is an acknowledgment of the challenges in interpreting the setup of the problem correctly.
rockmorg
Hey all -
I'm going insane because I can't think of how to do this...
I can't for the life of me get this straight... I have a triangle that I'm trying to solve for the hypotenuse, angle theta is 70 degrees and I know the adjacent leg is 7500. Cosine SHOULD solve for the hypotenuse, right (adjacent/hypotenuse)? I can't get it to solve for the hypotenuse.
I set it up like this:
cos70 = 7500/y
I need to get the 7500 on the side with the cos70, but wouldn't I have to multiply the right by 1/7500 to cancel it on that side for y (hypotenuse)?
Any help would be appreciated, I'm running into this over and over with my probelms.
Thanks!
Morgan
Just invert both sides:
1/cos 70 = y/7500
then solve for y
I have to be missing something... because there is a similar problem where they basically (diff. numbers) make it (7500)cos70 = y
I'm no expert but I did it like this..
cos70 = 7500/x x= hypot
cos70 = .3420
.3420 = 7500 /x
.3420x = 7500
x = 7500 / .3420
x = 21929.82456
rockmorg said:
Hey all -
cos70 = 7500/y
Thanks!
Morgan
OK
Here's another approach:
You have it set up correctly.
Multiply both sides by y to get the y out of the denominator on the RHS:
y*cos 70 = 7500
then solve for y.
The "similar problem" is not the same as this one. This is just a couple of fractions that are making your head hurt. Think about how you would solve this:
2 = 1/x
you can either take the inverse of both sides to get
1/2 = x
or you can multiply both sides by x to get
2x = 1
and then solve for x.
It's the exact same result.
hope this helps.
hmmm okay I'm seeing it is not the same as the other problem that I thought was the same... so your answers make sense.
thanks guys!
  • · Replies 38 ·
  • · Replies 33 ·
  • · Replies 38 ·
