Solving for Platform Recoil in Momentum Problem with Two People | HW Help
  • Thread starter Thread starter Parzival
The problem involves two people on a floating platform and the conservation of momentum when one person throws a ball to the other. The total mass of the system, including the platform and the two people, is 118 kg, and the ball has a mass of 6.0 kg. The key concept is that the center of mass of the entire system remains unchanged due to the absence of external horizontal forces. To solve for the platform's recoil distance, one must analyze the position of the center of mass before and after the ball is thrown. Understanding the movement of the center of mass will lead to determining how far the platform moves before coming to rest.
Parzival
Two people are standing on a 2.0 m long platform, one at each end. The platform floats parallel to the ground on a cushion of air, like a hovercraft. one person throws a 6.0 kg ball to the other, who catches it. The ball travels nearly horizontally. Excluding the ball, the total mass of the platform and people is 118 kg. Because of the throw, this 118 kg mass recoils. How far does it move before coming to rest again?
Momentum after = momentum before
I realized that conservation of momentum applied, but I couldn't set up any equations.
You might consider approaching this problem by thinking about what happens to the position of the center of mass of the entire system.
Do you know the velocity with which the ball was thrown?
May you please clarify? I've been stumped for a long time.
Take the system to consist of the platform, the two people, and the ball. There are no external forces acting horizontally on the system. So, the center of mass of the system relative to the ground will remain in the same place.
Suppose the person on the left end of the platform initially holds the ball. Where would the center of mass of the system be relative to the center of the platform? When the person on the right has the ball, where is the center of mass of the system relative to the center of the platform? From this, try to see how far the platform must move in order to keep the center of mass at the same location relative to the ground.
