Solving for tesnion and acceleration
  • Thread starter Thread starter wesleyneary
    Acceleration
The discussion revolves around solving equations related to the motion of two objects, focusing on tension and acceleration. The user has calculated the normal force (FN) and kinetic friction (Ff,k) but is struggling to find acceleration (a) and tension (FT) due to algebraic errors. Suggestions include simplifying notation for clarity and ensuring all variables remain in place during calculations. A common mistake identified is the misplacement of a minus sign, which can lead to cancellation of the variable being solved for. Careful step-by-step algebra is recommended to avoid such errors and accurately solve the equations.
wesleyneary
I am stuck on a piece of my homework assignment
here it is
The following equations describe the motion of a system of two objects.
FN - (6.50 kg)(9.80 m/s2) cos(13.0˚) = 0
Ff,k = 0.360(FN)
FT + (6.50 kg)(9.80 m/s2) sin(13.0˚) - Ff,k = (6.50 kg) a
-FT + (3.80 kg)(9.80 m/s2) = (3.80 kg) a
(a) Solve the equations for a and FT. (b) Draw a free-body diagram for both objects. (c)
Describe a situation to which these equations apply.
I have solved for FN and then solved for Ff,k using that information
FN=62.07N and Ff,k+22.35 N (assuming i did my algebra correctly)
form here i know if i solve for acceleration of Ftension i can solve for the other.
I tried using a system of equations to solve for "a" by solving for Ft in on equation and plugging it into to other. when i do that i end up with the variable I am solving for cancelling out.
Any suggestions?
It will help you see more clearly if you simplify your nottation - call the normal force N, the friction f, and the tension T. I don't know what your notation Ff,k may be.
It also helps to leave all the variables in place and do the algebra before plugging the numbers in.
You have made a mistake in the algebra - I suspect you misplaced a minus sign.
Go through it formally starting from the two equations you are using, write them down, write down each step in the process, take care of the minus sign when you do the substitution and again when you solve for a.
