Solving for Theta: A Physics-Math Dilemma
  • Thread starter Thread starter Ryuk1990
    Theta
To solve for theta in the given physics-math dilemma, the equations Tsin(theta) = 200 and Tcos(theta) = 400 can be used. Dividing these equations yields tan(theta) = 200/400, which simplifies to tan(theta) = 1/2. This method is valid as long as T is not zero. After finding theta, substitute it back into either original equation to determine the value of T.
Ryuk1990
This is originally from a physics problem but it's more of a math question. How do I solve for theta?
400 - Tcos(theta) = 0
-200 + Tsin(theta) = 0
Using those equations, I need to solve for theta. Also, knowing that tan(theta) = sin(theta)/cos(theta) is supposed to be relevant to this.
All I did was simplify the equations to 200 - Tcos(theta) + Tsin(theta) = 0
Not sure if that was a good idea or not but I'm suck.
Your equations can be rewritten as
Tsin(theta) = 200
Tcos(theta) = 400
Instead of adding equations to each other, what about dividing each side of one equation by the corresponding side of the other?
Place all the constants on one side of the equality for each of the equations.
Then remember that sin2θ+cosθ=1.
so something like R2sin2θ+R2cos2θ=1
Tsin(theta) = 200
Tcos(theta) = 400
Do you mean as in like this?
Is this legal?
Yes :smile:
You can even take a slower approach to solve the two simultaneous equations:
Tsin\theta=200 (1)
Tcos\theta=400 (2)
Re-arrange (1) : T=200csc\theta (3)
Substitute (3) into (2) : 200csc\theta cos\theta=400
Simplify : tan\theta=1/2
So yes, if you are convinced that substitution is a valid step in solving simultaneously, then the process of dividing both equations together is also.
Is this legal?
Sure, it's legal, as long as T isn't 0, and I'm reasonably sure in this problem it isn't. Once you get a value for theta, then substitute into either of the original equations to find T.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
