Solving Kinetics Questions: Two Cars Traveling on a Highway
  • Thread starter Thread starter aquapod17
    Kinetics
Two cars are traveling on a highway at speeds of 55 mi/h and 65 mi/h, respectively. For part (a), the faster car arrives at a destination 10 miles away 10.91 minutes sooner than the slower car. To solve part (b), the discussion emphasizes using the relationship between speed, distance, and time to determine how far the faster car must travel to achieve a 15-minute lead. The solution involves adjusting the distance based on the time difference established in part (a). The conversation concludes with the user gaining clarity on the problem-solving approach.
aquapod17
Two cars travel in the same direction along a straight highway, one at a constant speed of 55 mi/h and the other at 65 mi/h.
(a) Assuming that they start at the same point, how much sooner does the faster car arrive at a destination 10 mi away?
______ min
(b) How far must the faster car travel before it has a 15-min lead on the slower car?
______ mi
I'm not sure how to set up an equation.
I divided 10 mi by each speed, then multiplied each result by 60 and compared minutes.
For part a you seem to have started off correctly. All you need to do is find the difference in arrival times.
Any ideas for part b?
Welcome to PF, aquapod17.
You did part (a) correctly. The relevant equation is the one that relates speed, distance, and time to each other. (You must have been told this equation, or it's in your textbook ... otherwise you would not be asked to do a problem like this.)
(b) Instead of 10 miles, what would the distance be so that your answer is 15 minutes? You already know, from part (a), if that distance is greater than or less than 10 miles.
Thanks I got it!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
