Solving Limit of log(sin(x))/log(x) without L'Hopital's Rule
  • Thread starter Thread starter catapax
The discussion centers on finding the limit of log(sin(x))/log(x) as x approaches 0 without using L'Hôpital's Rule. Participants emphasize the importance of defining the limit correctly, noting that it is a right-sided limit since the logarithm is only defined for positive values in this context. One suggested approach involves using the limit property of sin(x) as x approaches 0 and manipulating the logarithmic expression algebraically. There is also a debate about the necessity of considering left-sided limits, with the consensus leaning towards focusing on the right-sided limit due to the function's domain. Ultimately, the limit can be successfully evaluated by applying logarithmic rules and known limits.
catapax
Hello, i am new here and this is my first post, so please bear with me for any mistakes or so... and sorry for my english that is not so good
now my question is about the solution of this limit: lim log(sin(x))/log(x) x->0, without using de l'hopital... thank you in advance
Do you have an idea for the limit?
You can replace sin(x) by an upper bound, and solve an easier problem afterwards.
First you have to consider if the limit is even defined. For a limit to exist, the left and right handed limits have to exist, and they have to be equal. In this case, what happens with the log functions when you try to take the left-sided limit (i.e. as x tends to 0 from very small negative values)?
It is a right-sided limit, obviously.
And where is that stated? "Obviously"?
It is so obvious that it is not necessary to write it here.
To consider a left-sided limit, you would need a function which is defined there. While it is possible to define the logarithm of negative numbers, I do not expect that catapax works with complex numbers.
##f: \mathbb{R}^+ \to \mathbb{R}##, ##f(x)=\frac{log(sin(x))}{log(x)}## has a well-defined limit for ##x\to 0##. This is identical to the right-sided limit.
Besides, the limit does exist even if you let x to be complex…
Anyway, I think you could show this by using the definition of limits using epsilons and deltas. Start by guessing the correct value for the limit (it should be pretty easy to guess) and then prove it.
i tried to solve the limit in this way, but i think it is not correct: logx=y,
so lim log(sin(e))^y/y => lim log(sin(e))... but it is wrong, the results should be 1
When the limit is simply written as x -> 0 (as opposed to x -> 0+), I don't think it can simply be assumed that the right-sided limit is the one being asked for.
Hence, it is invalid to assume that the limit exists simply because the right-sided limit exists.
Yes, the left-sided limit exists if we extend the range of log(x) to the complex numbers. But that is not the usual unqualified definition of the log function.
Anyway, *assuming the question is asking for the right-sided limit* (and therefore the limit can be assumed to exist), the most elementary way to solve this is to subtract \frac{\log x}{\log x} = 1 from the expression and see what it reduces to using algebra and the rules of logs. You still need to use the result \lim_{x \rightarrow 0} \frac{\sin x}{x} = 1. If you are not allowed to assume this result, you can prove it easily with the Taylor series for sin(x). Remember to add one back to what you get at the end to find the original limit.
ok, i succeed doing it, thank you!
Careful: I did not say that!
In the general case, the limit applys to the whole neighborhood where the function is defined. If that is on the positive real axis only (like in this problem), the limit is identical to the right-sided limit.
If the function is defined for positive real values only, both limits are identical.
