Solving Momentum Collision: Finding Velocity of Sliding Blocks | Homework Help
  • Thread starter Thread starter runningirl
    Momentum
The discussion revolves around a physics problem involving momentum and kinetic friction. A small block collides with a larger block at rest, causing the larger block to slide 72 cm before stopping, while the smaller block moves 1.5 m in the opposite direction. To find the initial velocity of the small block, the conservation of momentum and energy equations are applied, considering the effects of friction. The friction force is calculated using the mass of the blocks, gravitational acceleration, and the coefficient of kinetic friction. The participants are seeking assistance in solving for the initial velocity based on these principles.
runningirl
A small (35 g) block is sliding toward the right along a table when it hits a larger (90g) block that was at rest. After the collision, the large block slides 72 cm to the right before coming to a rest , while the small block bounces off the large block, sliding 1.5 m to the left before stopping. The somewhat rough table has a coefficient of kinetic friction of 0.42. What is the velocity of the small block just before it hits the larger block?
so i have to find the final velocity of the larger block...
which could be .72(.42)(.09)?
then i use the conservation of momentum equation?!
you could consider conservation of energy.
The inital block has energy
Ke= \frac{1}{2} m v^2<br />
where v is its velocity
m is the mass.
The second block has lost all its energy overcoming the friction of the table by the time it comes to rest.
As Work done = force*distance
friction force = mass of object* acceleration due to gravity * friction coefficient
can you solve from there?
yes, thanks so much!
