Solving Neuton's Second Law: Mass and Tension Calculations for Hanging Objects
  • Thread starter Thread starter chocolatelover
    Law Second law
The discussion focuses on solving a physics problem involving two objects of unequal mass hung over a frictionless pulley. The key equations for tension and acceleration are established, with the acceleration calculated as ay = (m2 - m1) / (m1 + m2) * g. There are clarifications regarding the signs used for gravity and the direction of acceleration for each mass, emphasizing the importance of consistency in defining axes. Tension is confirmed to be a force measured in Newtons, not kilograms, and while the magnitudes of the accelerations are equal, their vector directions differ. The conversation highlights common mistakes and the need for clarity in calculations and vector definitions.
chocolatelover
Two objects of unequal mass are hung vertically over a frictionless pulley of negigible mass. Determine vector a1, vector a2, and the tentions. m1<m2
ΣFy=t-m1g=m1ay
ΣFy=m2g-T=m2ay
-m1g+m2g=m1ay+m2ay
ay=m2-m1/(m1+m2)g
ay=(m2-m1)/(m1+m2)h
ay=(15-5kg)/(15kg+5kg)(-9.8m/s) (Would gravity be negative?)
=4.9m/s^2
Is a1= a2? that is, a1=-4.9m/s^2 and a2=-4.9m/s^2
T=m1(g+ay)=(2m1m2)/(m1+m2)g
T=5kg(9.8m/s^2+9.8m/s^2+4.9m/s^2)
=2(5kg)(15kg)(9.8m/s^2)/(5kg+15kg)
T=73.5kg
Does this look right?
Would you also get the same answer if you did vector a =change in velocity/change in time?
Thank you very much
ΣFy=t-m1g=m1ay
ΣFy=m2g-T=m2ay
You should make really clear what axis you are using. Is it clear to you what are the directions you are using? It's a bit confusing because you use two opposite directions for the two objects. But you can do that as long as everything is clear to you.
-m1g+m2g=m1ay+m2ay
ay=m2-m1/(m1+m2)g
ay=(m2-m1)/(m1+m2)h
=4.9m/s^2
well, you made two mistakes which by luck canceled out, leaving you with the correct answer. You should have used +9.8 for g. And you made a mistake in going from the first to the second line since you dropped the minus sign.
Are you talking about (a__y)_1 and (a_y)_2? To answer your question, you must make clear what your directions are for your two axis.
And why do you now have a minus sign when there was no minus sign on the previous line?
T=73.5kg
Thank you very much
A tension is a force so it's not in kg.
Thank you very much
It's along the y-axis.
I ended up getting kg(kg)(m/s^2)/(kg). Would that be kgm/s^2?
Is ay the same thing as vector a1? Vector a1 and a2 are equal, right? even though m1<m2, would the tention and gravity be the same?
Does it look correct now?
Thank you
Thank you very much
Yes, and that's the same as a Newton.
There are three things involved and people keep mixing them up which causes a lot of confusion. You may talk about the vectors \vec{a}_1, \vec{a}_2, you may talk about their components (a_y)_1, (a_y)_2 and you may talk about their magnitudes (usually written as a_1, a_2).
The two acceleration vectors are clearly not equal! But the two magnitudes are equal. As for the y components, it depends on the choice of y-axis for each object.
Thank you
It's not clear because you jump from positive to negative to positive values of the y acceelration.
Thank you very much
Regards
