Solving Physics Homework: Frictional Force & Speed of Baseball Player
  • Thread starter Thread starter jess_08
    Physics
The discussion focuses on solving a physics homework problem involving a baseball player sliding into home base. The player has a mass of 80.0 kg and a coefficient of kinetic friction of 0.610, leading to a calculated frictional force of approximately 478.725 N. Participants express confusion about how to approach the problem, particularly in drawing the free body diagram and determining the average force to find acceleration. The conversation highlights the need for clarity in applying physics equations and understanding the relationship between friction and motion. Overall, the thread emphasizes the importance of breaking down the problem into manageable steps.
jess_08
A baseball player of mass 80.0 kg slides into home base. The coefficient of kinetic friction between the player and the ground is 0.610.
a.) What is the magnitude of the frictional force? (In solving this part of the question draw a free body diagram with all of the forces labelled. Use a rectangle to represent the baseball player. Also, assume the player is moving to the right while sliding.)
b.) If the player comes to rest after 1.5 s, what must have been the initial speed of the player?
can you show your work? where are you getting stuck?
i don't even know where to start... like what do i do?
Fn
<-- Ff (0.610)RECTANGLE(80.0kg)----> Fa(his sliding)
Fg
Fk=mue Fn
Fk=(0.610)mg
Fk=(0.610)(80)(9.81)
=478.725N
ahha i honestly made up that answer for part a... but the FBD is right (:
k i understand that equation but how do i find the average force to find the acceleration in part b?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
