Solving Possion's equation: electrostatic potential
LocationX
I have the problem and my work uploaded to this webpage. I believe I have the general idea down, but I'm just afraid that I've done a careless calculation and missed a minus sign somewhere. I feel that my results have a lot of negative signs, making the potential constantly negative. I'm not sure if this is what is expected. Any help is appreciated.
http://sites.google.com/site/physicsinc/phy
You've made an error when applying the boundary conditions:
{\varphi}_{I}(R)={\varphi}_{II}(R), \quad {\varphi}_{II}(R+d)={\varphi}_{III}(R+d)
You've for some reason interchanged your constants C_0 and C_1 with C_3 and C_4; you can't do this.
You have 4 unknown constants to solve for, so you will need 4 boundary conditions. Luckily, \varphi isn't the only thing that is continuous; \vec{E}(r)=\vec{\nabla} \varphi must be continuous as well. This should give you your other two boundary conditions.
{\varphi}_{I}(r)=C_1^I
{\varphi}_{II}(r)=-\frac{4 \pi r^2 \rho }{6} + \frac{C_0^II}{r}+C_1^II
{\varphi}_{III}(r)=\frac{C_0^{III}}{r}
{\varphi}_{I}(R)=C_1^I
{\varphi}_{II}(R)=-\frac{4 \pi R^2 \rho }{6} + \frac{C_0^II}{R}+C_1^II
{\varphi}_{II}(R+d)=-\frac{4 \pi (R+d)^2 \rho}{6} + \frac{C_0^II}{R+d}+C_1^II
{\varphi}_{III}(R+d)=\frac{C_0^{III}}{R+d}
\frac{d {\varphi}_{I}{dr} |_{r=R} = 0
\frac{d {\varphi}_{II}{dr} |_{r=R} = \frac{8 \pi R \rho }{6} - \frac{C_0^{II}}{R^2}
\frac{d {\varphi}_{II}{dr} |_{r=R+d} = \frac{8 \pi (R+d) \rho }{6} - \frac{C_0^{II}}{(R+d)^2}
\frac{d {\varphi}_{III}{dr} |_{r=R+d} = - \frac{C_0^{III}}{(R+d)^2}
We use the 4 B.C.:
{\varphi}_{I}(R) = {\varphi}_{II}(R)<br /> {\varphi}_{II}(R+d) = {\varphi}_{III}(R+d)<br /> \frac{d {\varphi}_{I}{dr} |_{r=R} = \frac{d {\varphi}_II}{dr} |_{r=R}<br /> \frac{d {\varphi}_{II}{dr} |_{r=R+d} = \frac{d {\varphi}_III}{dr} |_{r=R+d}<br /> <br /> I&#039;ve already caught 2 minus sign errors... but this is how I&#039;m setting up everything to solve for the 4 constants.
Why not write it as:
{\varphi}_{I}(r)=C_0{\varphi}_{III}(r)=\frac{C_1}{r}
{\varphi}_{II}(r)=-\frac{4 \pi r^2 \rho }{6} + \frac{C_2}{r}+C_3
to get rid of those cumbersome superscripts and make it a little easier to work with?
You are still missing a couple of negative signs:
\frac{d {\varphi}_{II}}{dr} |_{r=R} = -\frac{8 \pi R \rho }{6} - \frac{C_0^{II}}{R^2}
\frac{d {\varphi}_{II}}{dr} |_{r=R+d} = -\frac{8 \pi (R+d) \rho }{6} - \frac{C_0^{II}}{(R+d)^2}
What do you get for your constants now?
You are missing a negative sign for C_2, which is affecting your other constants.
thanks for the help, I'm confident that i do not have any more errors after solving for the e-field and checking the BC and limiting cases
