Solving the limit of a function with no calculator
APcalchelp
The Limx-->infinity of the function Square rt(5x^4+2x) / (x^2)
Note* The square root is only in the numerator for the expression (5x^4+2x)
I have tried multiplying by the complex conjugate but I am not sure if this is the correct way to do it.
I did sqrt(5x^4-2x) over itself and got sqrt 25x^8-4x / x^2
I had that as my answer, but my teacher told me this was incorrect. If anyone could help and explain that would be great! Thanks a lot!
Factor x4 out of both terms inside the radical, and bring this out as x2. You should be able to evaluate the limit then.
I'm not clear on what you mean by that. I understand factoring out the x^4 from the 5x^4 but not the 2x.
If you factor out x^4 from 2x, you are left with 2/x^3.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
