Solving the Mystery of Star A & B's Distance
  • Thread starter Thread starter catgoesmeow
    Mystery Star
The discussion revolves around a problem involving relativistic travel between two stars, A and B, with specific distances and times given in light years and years. The problem requires calculating the speed of a spaceship traveling from Earth to Star A and then from Star A to Star B, considering the effects of time dilation and length contraction.
  • Participants discuss the calculations for the spaceship's speed and the implications of the gamma factor on the distance between the stars. There is uncertainty regarding the correct velocity to use for calculating the distance from Star A to Star B, with some questioning the use of previous values versus recalculating based on new conditions.
Several participants express differing views on the calculations and the values used, particularly regarding the gamma factor and its implications for distance. There is a recognition of discrepancies between the original poster's calculations and those found in solution manuals, indicating an ongoing exploration of the problem rather than a resolution.
Participants note that the problem involves relativistic effects and may require careful consideration of the definitions and assumptions related to time and distance in different frames of reference. There is mention of potential errors in the solution manual, which adds to the complexity of the discussion.
catgoesmeow
Star A and B are at rest relative to Earth. Star A is 27 ly from Earth, and as viewed from Earth, Star B is located beyond (behind) star A.
(a) Star A is 27 ly from Earth. A spaceship makes a trip from Earth to star A at a speed such that the trip from Earth to Star A takes 12 years according to clocks on the spaceship. At what speed relative to Earth must the spaceship travel?
(b) Upon reaching Star A, the spaceship speeds up and departs for Star B at a speed such that the gamma factor is twice that of part A. The trip from star A to star B takes 5.0 y (spaceship time). How far in light years is star b from star A in the rest frame of Earth and the two stars?
d = rt
Δt = Δt0 / γ
ΔL = L0γ
γ = 1/(sqrt(1-(v/c)^2))
So I found the first part, which is 0.914c.
I don't completely get the second part, but this is what I did:
v in part a = 0.914c
I calculated gamma, which came out to be 2.46.
So, I doubled it because that's what the question said happened.
gamma = 4.93
Then I calculated Δt (Earth time), which came out to:
Δt = 5 years/(1/4.824) = 24.65 years. So then I had to calculate the distance from star A to star B, and I did that by using d=rt. But first, I thought that I had to re-calculate the velocity since the spaceship had "sped up," so I calculated the new speed by doing:
1/(sqrt(1-(v/c)^2)) = 4.93
solved for v, and found v= 0.979c.
So then I used d=rt:
d = (0.979c)(24.65 years) = 24.13 ly
But the answer is 22.5 ly, and the solution says that they used 0.941c (from part A) instead. Why is this so? The gamma factor has changed because the spaceship's velocity has changed, right? So doesn't it make more sense to calculate a new velocity as well before trying to find the distance?
Thank you for your clarification!
I don't think they used 0.941c because that would not give the answer 22.5 ly. Your answer seems correct to me. P.S. welcome to physicsforums! :)
I got what the original poster got using the same method BUT the solution that I found is as he said, diffrent. I think they are using the length contraction formula for some reason. The solution we have is diffrent than what is in the back of the book. The back of the book matches up with the solution manual...
I think the OP meant to say that they used 0.914, and that does give the answer 22.5 ly. However, my analysis agrees with the answer given by the OP and by you. The answer book must be wrong.
  • · Replies 0 ·
