Solving the Rocket Equation: Confusion with Signs
The forum discussion centers on the confusion surrounding the application of signs in the rocket equation, specifically in the context of conservation of momentum. Participants clarify that the mass of the rocket decreases as it expels gas, leading to the equation \overrightarrow{v}M=(M-dM)(\overrightarrow{v}+d\overrightarrow{v})+\overrightarrow{u}dM. A critical point raised is the incorrect treatment of dM as negative, which leads to contradictions in the derived equations. The correct interpretation requires treating dM as a positive quantity representing mass loss, thus ensuring consistent application of momentum conservation principles.
  • Understanding of the rocket equation and its derivation
  • Familiarity with conservation of momentum principles
  • Knowledge of vector calculus and scalar equations
  • Basic grasp of LaTeX formatting for mathematical expressions
  • Study the derivation of the rocket equation in detail
  • Learn about vector calculus and its application in physics
  • Explore the implications of mass loss in rocket propulsion
  • Review LaTeX syntax for proper formatting of mathematical equations
Students and professionals in aerospace engineering, physicists, and anyone interested in the mathematical foundations of rocket propulsion and momentum conservation.
calculus_jy
recenty i read the rocket equation, derivation of, however i think i have a slight confusion with signs
suppost initially a rocket has
mass= M
velocity= \overrightarrow{v}
then at a time dt later,
mass of rocket= M-dM
velocity of rocket= \overrightarrow {v} +d\overrightarrow {v}
mass of ejacted gas= dM
velocity of gas= \overrightarrow{u}
using conservation of momentum
(\overrightarrow{u}-\overrightarrow{v})dM+Md\overrightarrow{v}=0
but (\overrightarrow{u}-\overrightarrow{v})=velocity of gas relative to rocket
let (\overrightarrow{u}-\overrightarrow{v})=\overrightarrow{U}which is a constant
\overrightarrow{U}dM+Md\overrightarrow{v}=0
-\int_{M_0}^{M}\frac{dM}{M}=\frac{1}{\overrightarrow{U}}\int_{\overrightarrow{v}_0}^{\overrightarrow{v}}d\overrightarrow{v}
now -ln\frac{M}{M_0}=\frac{\overrightarrow{v}-\overrightarrow{v_0}}{\overrightarrow{U}}
the problem is , when taking the velocity in the direciton rocket is travelling
\overrightarrow{U}<0
-ln\frac{M}{M_0}>0since \frac{M}{M_0}<1
then
\overrightarrow{v}-\overrightarrow{v_0}<0 which is impossibe as the rocket is accelerating?
latex problem seems to be fixed now...
i don't see how you get <br /> M- dM<br /> is is because of E=mc^2
why won't the latex work
I hope this isn't too off topic but
i think you need [/tex] instead of at the end
Good up to this point.
-\int_{M_0}^{M}\frac{dM}{M}<br /> =\frac{1}{\overrightarrow{U}}<br /> \int_{\overrightarrow{v}_0}^{\overrightarrow{v}}d\overrightarrow{v}
This step is not valid. There is no such thing as the multiplicative inverse of a vector. Better is to define a unit vector v-hat directed along the rocket's delta-v vector. From the correct equation, this delta-v vector is directly opposed to the relative exhaust velocity vector. Thus
<br /> \begin{aligned}<br /> d\overrightarrow{v} &amp;= dv \hat{v} \\<br /> \overrightarrow{U} &amp;= U \hat{v} &amp; (U &amp;\equiv \overrightarrow{U}\cdot \hat v)\\<br /> &amp;= -v_e \hat{v} &amp; (v_e&amp;\equiv -U)<br /> \end{aligned}
Note that ve is simply the magnitude of the relative velocity vector. With this, the vector differential equation becomes the scalar equation
-v_edM+Mdv=0
from which
\int_{M_0}^{M}\frac {dM}{M} = \frac 1{v_e}\int_{v_0}^v dv
or
\ln\frac{M}{M_0} = \frac{\Delta v}{v_e}
You can use a vector formulation, but you can't divide by a vector like you did.
however is the equation
v=v_0+\overrightarrow{U}ln\frac{M}{M_0} not right?using the notion in the first post
in the step with the integrals, to prevent multiplicative of inverse of vector, simply put \overrightarrow{U}
on the same side of the equation as \frac{dM}{M}
i have been told that its the problem associated with dM such that the mass of rocket after dt is M+dM not M-dM
i don't get why minus can be used in scalar, but cannot be used in vercot derivation?
Your error occurs much earlier than I stated earlier.
Here your dM is the quantity of mass ejected by the spacecraft . With this definition, a positive dM means the spacecraft loses mass. Things would have worked properly if you had used dM as positive meaning the spacecraft gains mass. Then the conservation of momentum equation becomes
\overrightarrow{v}M=(M+dM)(\overrightarrow{v}+d\overrightarrow{v})-\overrightarrow{u}dM
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 0 ·
