Solving these non-numerical problems applying work and energy concepts
A block on a frictionless surface is pushed by a constant horizontal force, leading to constant acceleration. As it travels from point A to B, it reaches speed vB, and further analysis indicates its speed at point C will be greater than 2vB due to continuous acceleration. The discussion also touches on the energy dynamics of stepping over a log versus jumping down, highlighting that stepping over requires less energy as it avoids the potential energy loss associated with jumping down. Participants emphasize the importance of using equations of motion and work-energy principles to analyze these scenarios. The thread reinforces the application of work and energy concepts in solving non-numerical physics problems.
jrd007
Here they are...
(1) A hand exerts a constant horizontial force on a block that is free to slide on a frictionless surface. The block starts from rest at point A, and by the time it has traveled a distance d to point B it is traveling with speed vB. When the block has traveled another distance d to point C, will it's speed be greater than, less than, or equal to 2vB? Explain your reasoning.
My drawling, if you can undertand it...
Hand pushes block----------------------------------------<(surface)
~~~~~~~~~~~A----d----B----d----C
My first instinct is to say equal to since it is a frictionless surface therefore nothing will slow it down.
(2) Seasoned hikers prefer to step over a fallen log in their path rather than stepping on top and jumping down on the other side. Explain.
No idea... but I was thinking because it takes twice as much energy to step on top of and then down than it does to just stepp over?
(Thanks to all who help)
Part 1)
The block is pushed with a constant force, hence a constant acceleration.
The block is accelerating from A to B and from B to C.
Can you now compare the velocities at B and C again ?
Part 2)
It takes more energy, yes. Think potential.
So the velocity with be more when it reaches B-C?
I was thinking they would be equal... I guess not.
Greater than, because it is gaining momentum?
Have you worked out the eqn of motion for the block ?
Use this to determine the speed of the block at the points B and C.
Use these results as justification for your answer to the question posed.
This was supposed to be Work & Energy practice, right?
Compare Work done thru the displacement "a" to "b"
with Work done thru displacement from "a" to "c".
What form of Energy does this Work show up as?
What's the functional form ("formula") for KE?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
